First upgrade?
I have a dd m2b amp and its pulling to much for my stock electrical. And I only have enough money for either another battery or alternator. Which would be more helpful? Any suggestions would be appreciated, thanks
What ohm load do you have on it?
Have you done big 3 yet ?
I'd do alt first then add a good battery, just save up.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
1st things first.. get your big three done ASAP. Common thing to do. When you add an amp that is capable of pulling 200A or more for ex. Its trying to pull that all through the stock ground wires and whatnot, (which on my honda consisted of an 8g wire from the (-) batt to the chassis. Thats how it came factory and the design was not engineered for extras. Yes im aware you will not see 200A or draw being stock alt but it will certainly try draw :) another thing the DD line are rated @12v so 1700rms is not bad. I would do big three and definetly a battery first. You dnt really want a good alt and a crappy batt just my opinion. But with that amp your not off to a bad start. Just keep doing the baby steps and it will get better.
1995 Integra GSR (DB8)
Pioneer 3200-DVD
6.5 rockford fosgate 2-way fronts
6.5 rockford fosgate 3-way rear
saz-3000D
(2) 12" SA-12s
x2 on big 3. that should always be the first thing you do.
an alternator will solve almost all of your voltage drop. a battery will just let you play a little longer before dropping to X volts.
  • Who's Online   0 Members, 0 Anonymous, 1560 Guests (See full list)
