Please help. Subs messed up
djscrappydee
Help guys I was just playing my subs normal like I always do and I went and turned down the subwoofer level down on my radio and I turned it back up they made this scrapping/knocking noise when it was turned up half way. I took the subs out and looked at it nothing looked bad. Pressed down and it wasn't scrubbing. Didnt smell bad or anything. I free aired both of them and nothing sounded bad. I checked the box looked normal for what I seen. Wtf could it be? Help please (subs are 2 sa-12s on crescendo 2000)
(2) PSI p2 18's
Crescendo 2000
Audio Technix 0 gauge/ SHCA 0 gauge
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
I took all the wire out and was so cold I didn't hook it back up ill wire it up tomorrow and make a vid. Best way I could explain the sound was like something was slapping the inside of my box but it wasn't. Could they be blown?
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
Did you check the box to make sure something didn't come loose? I've had those plastic speaker terminal cups crack on me before and make an awful noise
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
I don't have terminals and everything looks fine in the box
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
Do you have a multimeter? Check the resistance of the coils, if any of them are a significant amount off on resistance from what Sundown says they should be then chances are that coil is blown. Would be a good way to rule out a blown coil though.
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
How do you check that I got a multimeter
set the meter to ohms and put the red lead on the positive lead on the terminal and put the black lead on the negative.
https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U
2013 DODGE CHALLENGER R/T
SUNDOWN ZV4-18
CRESCENDO 3.5K
PIONEER AVIC 5300 NEX
ALPINE TYPE R 6.5S & 6X9'S
ROCKFORD FOSGATE 1.5" TWEETS
5 C&D TECH BATTS
They were 4 all way around. Thought is might be the amp so I switched amps and still same thing. Gonna send them and get Spl parts put on
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
  • Who's Online   0 Members, 0 Anonymous, 2422 Guests (See full list)
