where to set the crossover point for tweeters?
Dylan_Grant
It depends on what tweeters you use but most are over 2500hz. Some large format tweeters and ribbons play lower and compression drivers like the ones in my horns play down to 800hz. I use the mbquart amps for my frontstage. They have 24 db slopes.
the spec sheet said frequency response (-10 dB) is 800- 45 kHz but they are not horns
ill probably just use the crossover and get a processor
So what are you going to do ... Just run your amps in "bypass" or "Full range" mode ???
yes ill use the crossover the set came with i read good thing about it.
that 5khz part kind of defeats the purpose of running active doesn't it, because the crossover point is still fixed? or am i not understanding this, Im new to the stuff so im sorry.
  • Who's Online   0 Members, 0 Anonymous, 1541 Guests (See full list)
