99 blazer 4.3l Stuttering a little bit
check plugs and under distributor cap
Hammerdown... 1%
Its worth it to check it out pressure should be in mid 50s. The other common problems for loss of power and sputtering are bad MAF sensors and clogged cats. Do you have any trouble codes on the computer?
to add, if you keep driving on a bad MAF sensor, the cat may end up getting ruined because of said sensor.
^That's a good add on there. And if you need to test the cats, easiest way without running the motor would be to unbolt them and shine a flashlight down the middle. If you cant see it on the other side, you've got a bad cat
maf should be good its only 2 yrs old but it has that crack that is concerning me. and i havnt got codes pulled yet. it just recently started doing it. my friend told me try checking the fuel filter
08 Ford F150
Ok, I just had this problem, check 02 sensors then clean MAF, you said you already cleaned it... what did you use??
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
check your 02 sensors, they get gummed up when your engine runs too rich.
Build log: Click
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
