99blazer Posted January 20, 2013 Report Posted January 20, 2013 Ive recently started having this problem. when i pulled out of my drive way ( i live on a busy street) i tryed to gun it and my blazer just hesatated to go so i let off the gas a bit and slowly had to accelerate. i was thinking it was the maf sensor. ive cleaned and it seemed to help but it might just b a temp fix. and i took a pic of the maf and i found a crack do you think this could be the problem? 08 Ford F150
fox_racin4 Posted January 20, 2013 Report Posted January 20, 2013 ill try and figure out what it is.. your issue is very common on the blazers its a sensor i just forget which 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Guest Posted January 20, 2013 Report Posted January 20, 2013 my buddys jimmy (same car) had stuttering issues. im almost positive it was the MAF sensor gone bad.
flwatersaver Posted January 20, 2013 Report Posted January 20, 2013 scan it to see if it is a miss fire. i had to replace my injectors. My selling FeedbackBuild log - Blazer C pillar wall, Two DC Audio 3.5k'sTEAM PSI
ToNasty Posted January 20, 2013 Report Posted January 20, 2013 The iac goes bad frequently on those ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
99blazer Posted January 20, 2013 Author Report Posted January 20, 2013 i dont wana stick much money in it i just gotta keep it going till i get my new car in a couple of months 08 Ford F150
Pioneerchuck Posted January 20, 2013 Report Posted January 20, 2013 I know on the suburbans and Tahoes of the old body styles had this problem when their fuel pumps were on their way out. Not sure if the pumps are the same but its a simple test to make sure its good.
99blazer Posted January 21, 2013 Author Report Posted January 21, 2013 just got a new pump in 2009 08 Ford F150
Pioneerchuck Posted January 21, 2013 Report Posted January 21, 2013 Its worth it to check it out pressure should be in mid 50s. The other common problems for loss of power and sputtering are bad MAF sensors and clogged cats. Do you have any trouble codes on the computer?
