FINISHED! Wookie's 2dr Explorer C-pillar wall.
Thanks! I'll keep an eye on it
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Okay guys. Got all of them playing, after about 15 seconds i could smell something cooking. Checked out the amps, check. Smelt the port... mmm coils (i think?).
So i watched the subs as i played them lightly, and one of the 4 is moving more than the others. Maybe a wire came loose inside? What do you think?
p.s. Yes i noticed the amps. I have no explanation.
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
check your ohm reading on your coils and voltage too. if your voltage drops too low your amps will clip and your coils will go after that
your batt isolator might make your alternator over work trying to split the charge for regular car use, recharging your rear batts, and keep voltage up for your amps. also on these amps each channel doesnt put out equal power but i wouldnt think it would be off that much. seen someone say they got 9++ on one channel and 8++ on the other so they couldnt run it split to one sub. hope this helps nice work on the build too :drink40:
Ill have to check the ohms tonight. Pstone suggested the isolator was probably more harm than good too . Different power both when separated?? That would really suck. Should i just run them bridged? Good link on the alt!
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Alright everyone i figured it out. The amps tuning were out of sync enough to cause the problem. Wish i had money for a dd1!! Everything is good now. Huge thanks to Jon at SecondSkin! 32sqft of bstock was the perfect amount and it sounds so good. Time to save for electrical upgrades: dual alt bracket, upgraded alts, another or two optimas because i can fit 2 easily.
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
  • Who's Online   0 Members, 0 Anonymous, 3131 Guests (See full list)
