TimberWolf Posted January 26, 2013 Author Report Posted January 26, 2013 I was going to run another 1/0 from the alt to the back battery but I'm prob going to get a XS batt from Mechman since I already have a D1200 for the back battery. Like they said above if your batteries are of the same composition and close on specs then you could wire them together if not then just take a run to your alt Thanks bro
meade916 Posted January 26, 2013 Report Posted January 26, 2013 don't use an isolator. First of all it won't benefit you at all. Second they are actually BAD for the alternator. Think about it. The worst thing you can do to an alternator is hook up a dead battery to it and start your car. Sure, it will start the car on the 2nd battery if you drain the system battery, but once that dead battery is re-introduced into the system, it is bad news. The alternator is not going to blow up but it WILL get hot and it will have a MUCH shorter life. Try to avoid playing your system when the car is NOT running and you should be good. If you insist on playing it with the car OFF then turn the volume down to reasonable levels and cut the bass too so it doesn't tax the battery's very hard.....and don't do it for too long. With or without an isolator, you don't ever want to show your alternator a dead or very low battery. I believe a charged battery can be around a 10a load by itself but a discharged battery can show a 100a load or more while it tries to catch back up again. IMO, say no to isolators. All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
TimberWolf Posted January 26, 2013 Author Report Posted January 26, 2013 don't use an isolator. First of all it won't benefit you at all. Second they are actually BAD for the alternator. Think about it. The worst thing you can do to an alternator is hook up a dead battery to it and start your car. Sure, it will start the car on the 2nd battery if you drain the system battery, but once that dead battery is re-introduced into the system, it is bad news. The alternator is not going to blow up but it WILL get hot and it will have a MUCH shorter life. Try to avoid playing your system when the car is NOT running and you should be good. If you insist on playing it with the car OFF then turn the volume down to reasonable levels and cut the bass too so it doesn't tax the battery's very hard.....and don't do it for too long. With or without an isolator, you don't ever want to show your alternator a dead or very low battery. I believe a charged battery can be around a 10a load by itself but a discharged battery can show a 100a load or more while it tries to catch back up again. IMO, say no to isolators. So I should just run straight back from the alt
TimberWolf Posted January 26, 2013 Author Report Posted January 26, 2013 My current sub amp is only 1000wrms and its run straight 5.5ft on 4 gauge from a 1000 cranking amp main battery.. At full tilt my volts drop from 14.7v to 13.96v while idling
Guest Posted January 26, 2013 Report Posted January 26, 2013 ugh... alt to front battery. front battery to rear battery. rear battery to amp.
Noel989 Posted January 26, 2013 Report Posted January 26, 2013 Just add a second battery Run cable from alt to front battery to the back battery Build Log - http://www.stevemead...-cruiser-el-pt/
TimberWolf Posted January 26, 2013 Author Report Posted January 26, 2013 Thanks for the help everybody.. Looks like I know what I gotta do now..
