winning feed back through all my speakers? NEED HELP
Ground them at the head unit.
Also double check all your connections and make sure the RCAs aren't next to the power wire
That's genius.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
so my RCAs are like the hanging kind it has like heat shrink at the bottom where it meets the headunit but i can see the wires in there how do u rewire it
I took a length of wire and stripped the insulation off of it and did the same grounding method pictured earlier in this thread but at the end of the RCA "dangle". I used zip ties to hold the stripped wire to the RCA grounds then grounded the end to the HU chassis. This worked for a short time and now the whine is back slightly, gotta get in there is do something better to secure the ground to the RCAs. Maybe a spot of solder on each one with work better.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 729 Guests (See full list)
