Recommended amp for sundowns?
Joshex
My friend has 2 sa8v2d2 sundowns and they are rated at 2 ohms dvc. He wants to run 1000 rms per sub. What amps should he use and how should he do it? He is trying to find good deals on amps as well.
95 Acura Integra - 5-speed
Pioneer FH-X700BT
(2) Rockford Fosgate 12" P3
AQ1200d
Rockford Fosgate P1652-S 6.5" components
Rockford Fosgate P1572 5x7"
Rockford Fosgate R400.4
95 Integra Build Here
93 EJ2 Build Here
That's a lot of power to run to those subs. I'd recommend the AQ2200D. It's on sale right now and it's pretty damn cheap, but he won't be getting 1K watts each sub since the final load will be 2ohm.
2 HDC3 18's
AQ2200D
He have to run the sub´s on 2 Ohm´s or 0.5 Ohm´s. Have a look on the sale from Soundqubed (AQ) for a AQ 3500 http://www.soundqubed.com/Mono-Block_c_29.html
for running on 2 Ohm, or for 0.5 Ohm a Lanzar Opti http://www.ebay.com/itm/NEW-LANZAR-OPTI2000D-2000W-CLASS-D-MONO-CAR-AUDIO-AMPLIFIER-AMP-2000-WATT-/271111376654?pt=Car_Amplifiers&hash=item3f1f7f4f0e.
"in the abundance of water, the fool is thirsty" Bob Marley
Thanks for the suggestions guys. I would like as much input as possible.
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
Alright thanks josh :)
To anyone who sees those are my subs he posted about.
The deal is that I had one if them running off of a kicker 500.1 amp at 1 ohms running 500 watts rms and one of the terminals melted and also it was not close to as loud as I though it would be, I don't think 2 of them at 1000 watts rms would be either, I went into a sub store and told the owner and he said the terminal melting is no big deal to just attach my speaker wires directly to the voice coil leads and to run them at 1000 watts rms a piece
Your thoughts? Very open to any suggestions
No problem mayne! We need to build up a box design some time.
Pioneer FH-X700BT
AQ1200d
93 EJ2 Build Here
I have a soundqubed (AQ) 1200d and I love it, so my vote would be for the AQ 2200d. Just read all of the great reviews about it on soundqubed's website.
Ummm WHAT??????
  • Who's Online   1 Member, 0 Anonymous, 1074 Guests (See full list)
