*** Skar Audio VVX*v2* Information Thread ***
The time has finally come to announce full specifications as well as pictures on the completed VVXv2 Subwoofer line up! We will not be doing a Pre-Order on these right now, but they are due soon!
ETA : March 5th, 2013
Nearly two years has passed since we initially launched the VVX Series subwoofers, and ever since the launch, they have been making waves in the car audio community everywhere. We are now proud to announce the launch of what our engineers have been working on for more than one year now…The VVXv2 Subwoofer line up! The VVXv2 was redesigned from the ground up to innovate and improve on every aspect of our 600 Watt RMS line up.
The Skar Audio VVXv2 Series subwoofers were designed to withstand brutality, sound amazing, and recreate low end response that will make your car tremble. With a completely unique new basket & design; the woofers are capable of enormous excursion, creating earth shattering responsive bass. They feature a brand new competition grade foam surround which is very accurately stitched to its premium paper cone. Utilizing a three piece ferrite magnet motor assembly along with a 2.5” voice coil, the vvx series is conservatively rated at 600 watts RMS power!
The VVXv2 lineup is available both in Dual 2 Ohm and Dual 4 Ohm Voice Coil configurations and comes in 10”, 12”, and 15” sizes. Whether you are looking to do a single subwoofer for that extra bass in your daily driver, or if you want to run sixteen of these woofers in a competition vehicle, the VVXv2 series will always impress!
Pricing Will Remain the Same as the VVXv1 once these arrive - but so many new features :-)
Technical Specifications
Available in D2/D4 Voice Coil Configurations
600 Watts RMS Power
2.5" Voice Coil
Triple Stack Ferrite Magnets (160mm * 20mm x 3)
Double Layer Spider
Premium Grade Foam Surround
High Quality Paper Cone
Xmaxx : 26.5mm
VVXv2-10 D2/D4
Re : 1.8+1.8 Ohms/3.2+3.2 Ohms
Res : 35.1 / 39.5 Ohms
Qms : 0.317 / 0.326
Qes : 0.294 / 0.258
Qts : 0.327 / 0.301
Rms : 5.8 / 5.2 kg/s
Cms : 0.28 / 0.26 mm/N
Mms : 337.4 / 326.2 gr
Nref : 0.19% / 0.17%
Bl : 26.9 / 28.2 n/a
Spl : 87.4 / 88.2 dB
Vas : 41.6 / 39.5 L
Rp : 20.1 / 22.9 Ohms
Lp : 29.8 / 28.4 mH
Cp : 683.9 / 724.1 uF
Le : 2.67 / 2.41 Mh
Xmax : 26.5mm
VVXv2-12 D2/D4
T//S Paramters D2/D4
Res : 39.5 / 45.6 Ohms
Qms : 0.395 / 0.371
Qes : 0.315 / 0.278
Qts : 0.38 / 0.315
Rms : 5.93 / 5.4 kg/s
Cms : 0.29 / 0.23 mm/N
Mms : 382.5 / 365.6 gr
Nref : 0.21% / 0.156%
Bl : 26.1 / 27.4 n/a
Spl : 87.2 / 87.9 dB
Vas : 71.3 / 65.8 L
Rp : 22.5 / 25.6 Ohms
Lp : 30.6 / 32.6 mH
Cp : 722.7 / 852.3 uF
Le : 2.18 / 2.60 Mh
Xmax : 26.5mm
VVXv2-15 D2/D4
Res : 42.3 / 56.5 Ohms
Qms : 4.23 / 3.256
Qes : 0.776 / 0.685
Qts : 0.45 / 0.39
Rms : 7.2 / 6.4 kg/s
Cms : 0.45 / 0.36 mm/N
Mms : 346.5 / 325.3 gr
Nref : 0.18% / 0.14%
Bl : 23.5 / 25.7 n/a
Spl : 86.5 / 87.8 dB
Vas : 268.2 / 253.9 L
Rp : 38.2 / 34.5 Ohms
Lp : 53.5 / 45.6 mH
Cp : 1295.5 / 1203.2 uF
Le : 3.09 / 3.6 Mh
Xmax : 26.5mm
Skar Audio
www.SkarAudio.com
Phone : (888) 501-7527
26.5mm Xmax?????? For realz?
That's Exactly what I was thinking. From 21 to 26 on 600w with a 2.5" coil. Hot diggidy damn.
I noticed that first as well. Damn, I want a pair.
1993 Suburban
6 Crossfire XT3 15s
Crossfire XS-16k
Crossfire mids & highs and amps
65ah Cmax bank
Iraggi 320a and Mechman 300a
I still like the inverted dust caps that were on the vvx V1. But these seem awesome!!
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
Same here. I'll probably order the v1's still just for that reason.
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
  • Who's Online   0 Members, 0 Anonymous, 1047 Guests (See full list)
