RooTxBeeR Posted February 1, 2013 Report Posted February 1, 2013 aero ports are based on 9-13 square inches per cubic foot. so the 9-13 square inches were they need to come. in the port area or in the port area per foot? tx guys for helping me They refer to Port area per foot. With slot port boxes, 12-15 Port area per foot. Less port area, the more bandwidth you will have, and the lower you will be able to play below tuning. The more port area, the less bandwidth you will have, but in your "peak" area range, you will be louder than if you had less port area. A bigger box allows lower notes to be more defined, while at the same time, lowering power handling. It is the complete opposite for smaller boxes, a smaller box allows for more power handling but hinders low end. It is all a game of balance when building boxes, and building it to fit what you want to outcome from it. Hope that helps you man. thats not completely true at all. Care to explain? I have a 2.5Cuft box, 28Hz tuning, and about 14sqin of port are per foot, for a 15". Cant barely play below 40hz, and your telling me that it doesn't? If your going to call someone out on something, please explain why. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Guest Posted February 1, 2013 Report Posted February 1, 2013 aero ports are based on 9-13 square inches per cubic foot. so the 9-13 square inches were they need to come. in the port area or in the port area per foot? tx guys for helping me you just answered your own question within like ten words.
vw passat Posted February 1, 2013 Author Report Posted February 1, 2013 but on round port for me its difficult AI James iv never make a box with round port those someone can tell me some measurements for a 12'' with round port pls?
AI James Posted February 1, 2013 Report Posted February 1, 2013 aero ports are based on 9-13 square inches per cubic foot. so the 9-13 square inches were they need to come. in the port area or in the port area per foot? tx guys for helping me They refer to Port area per foot. With slot port boxes, 12-15 Port area per foot. Less port area, the more bandwidth you will have, and the lower you will be able to play below tuning. The more port area, the less bandwidth you will have, but in your "peak" area range, you will be louder than if you had less port area. A bigger box allows lower notes to be more defined, while at the same time, lowering power handling. It is the complete opposite for smaller boxes, a smaller box allows for more power handling but hinders low end. It is all a game of balance when building boxes, and building it to fit what you want to outcome from it. Hope that helps you man. thats not completely true at all. Care to explain? I have a 2.5Cuft box, 28Hz tuning, and about 14sqin of port are per foot, for a 15". Cant barely play below 40hz, and your telling me that it doesn't? If your going to call someone out on something, please explain why. your car plays a big roll in what your box is going to play in the first place. just because you tune a box at 28hz doesnt mean its going to play 28hz. Different subwoofers will react differently in those "retard boxes" that are small and tuned below the subs fs and below your cabins f3. but for you do say that the "rule" is a definite is incorrect. That box you explained i'd never make for a customer. Because it would fail in every build. Our demo truck...2.75 per 15 12 per cube PLAYS EVERYTHING Steves tahoe has low volume with small port area, it plays everything i want to say both are tunes around mid 30s i know for a fact ours can play anythign 25-55 over 152db's.
vw passat Posted February 1, 2013 Author Report Posted February 1, 2013 wow do have link to see your truck AI James?
AI James Posted February 1, 2013 Report Posted February 1, 2013 you can see the demo truck by checking out the read only Audio Innovations of Fresno section on this board.
RooTxBeeR Posted February 1, 2013 Report Posted February 1, 2013 aero ports are based on 9-13 square inches per cubic foot. so the 9-13 square inches were they need to come. in the port area or in the port area per foot? tx guys for helping me They refer to Port area per foot. With slot port boxes, 12-15 Port area per foot. Less port area, the more bandwidth you will have, and the lower you will be able to play below tuning. The more port area, the less bandwidth you will have, but in your "peak" area range, you will be louder than if you had less port area. A bigger box allows lower notes to be more defined, while at the same time, lowering power handling. It is the complete opposite for smaller boxes, a smaller box allows for more power handling but hinders low end. It is all a game of balance when building boxes, and building it to fit what you want to outcome from it. Hope that helps you man. thats not completely true at all. Care to explain? I have a 2.5Cuft box, 28Hz tuning, and about 14sqin of port are per foot, for a 15". Cant barely play below 40hz, and your telling me that it doesn't? If your going to call someone out on something, please explain why. your car plays a big roll in what your box is going to play in the first place. just because you tune a box at 28hz doesnt mean its going to play 28hz. Different subwoofers will react differently in those "retard boxes" that are small and tuned below the subs fs and below your cabins f3. but for you do say that the "rule" is a definite is incorrect. That box you explained i'd never make for a customer. Because it would fail in every build. Our demo truck...2.75 per 15 12 per cube PLAYS EVERYTHING Steves tahoe has low volume with small port area, it plays everything Those where general rules. Of course if you build a small box, then have low port area, that will greatly help bandwidth. If you read what I said, that conlcusion can be made. And my sub's Fs is actually lower than my port tuning fyi On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
vw passat Posted February 1, 2013 Author Report Posted February 1, 2013 so if my sub fs is 33.4hz what i need to do? and if i have like 13in^2vof port area is it good? tx bro
AI James Posted February 4, 2013 Report Posted February 4, 2013 aero ports are based on 9-13 square inches per cubic foot. so the 9-13 square inches were they need to come. in the port area or in the port area per foot? tx guys for helping me They refer to Port area per foot. With slot port boxes, 12-15 Port area per foot. Less port area, the more bandwidth you will have, and the lower you will be able to play below tuning. The more port area, the less bandwidth you will have, but in your "peak" area range, you will be louder than if you had less port area. A bigger box allows lower notes to be more defined, while at the same time, lowering power handling. It is the complete opposite for smaller boxes, a smaller box allows for more power handling but hinders low end. It is all a game of balance when building boxes, and building it to fit what you want to outcome from it. Hope that helps you man. thats not completely true at all. Care to explain? I have a 2.5Cuft box, 28Hz tuning, and about 14sqin of port are per foot, for a 15". Cant barely play below 40hz, and your telling me that it doesn't? If your going to call someone out on something, please explain why. your car plays a big roll in what your box is going to play in the first place. just because you tune a box at 28hz doesnt mean its going to play 28hz. Different subwoofers will react differently in those "retard boxes" that are small and tuned below the subs fs and below your cabins f3. but for you do say that the "rule" is a definite is incorrect. That box you explained i'd never make for a customer. Because it would fail in every build. Our demo truck...2.75 per 15 12 per cube PLAYS EVERYTHING Steves tahoe has low volume with small port area, it plays everything Those where general rules. Of course if you build a small box, then have low port area, that will greatly help bandwidth. If you read what I said, that conlcusion can be made. And my sub's Fs is actually lower than my port tuning fyi box design and building isnt ALL about fs of a woofer. hell the re 8" has an fs in the 20s and it will not play crap thats low 30s
