Raptorman Posted February 2, 2013 Report Posted February 2, 2013 Also the height for the port will be 16.5 not 16 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Joe X Posted February 2, 2013 Report Posted February 2, 2013 So here is a suggestion, really tight: Enclosure Specifications:Fb = 34 HzVb = 4.2 ft^3External Height = 18 inExternal Width = 34 inExternal Depth = 23 inPort Width = 3 3/4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 34 x 23Left & Right Sides = 21 1/2 x 15 3/4Front & Back = 34 x 15 3/4L Port Internal Assembly Parts:Top to Bottom = 12 x 21 1/2Extension = 17 1/4 x 21 1/2 Assembly guide (generic dimensions): - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All boxes built outside the car need to fit in their way in not just have the right dimensions.- Setting your amp's subsonic filter to 28Hz is suggested. Try both port driver's side and passenger side.
Rmichael91 Posted February 2, 2013 Author Report Posted February 2, 2013 The sketch up is just to show the port and bracing right Joe? How the dimensions were labeled made me question it. 18.75" is going to be extremely tight, thus I was sticking to 18" for the height. But that's making a lot more sense than what I put together in Torres. Raptor I caught that with the port height after I uploaded and posted that one, there wasn't an extreme difference on the volume or frequency tune.
Joe X Posted February 2, 2013 Report Posted February 2, 2013 The sketch up is just to show the port and bracing right Joe? How the dimensions were labeled made me question it. 18.75" is going to be extremely tight, thus I was sticking to 18" for the height. But that's making a lot more sense than what I put together in Torres. Raptor I caught that with the port height after I uploaded and posted that one, there wasn't an extreme difference on the volume or frequency tune. Definitely the sketch is of generic dimensions and just to show how things assemble and the braces, if you can't go up, could you go 1/4" or so wider or deeper?, is just that the box is real tight and making the most of your dimensions will be good for it.
Rmichael91 Posted February 2, 2013 Author Report Posted February 2, 2013 The most I can extend is the depth from 20". The height and width are to the nearest 1/4" I can spare. From the trunk floor up to the rear deck brace, and between the trunk arms. I was aiming for a flat amp rack, but I can rework that accordingly with the box.
Joe X Posted February 2, 2013 Report Posted February 2, 2013 The most I can extend is the depth from 20". The height and width are to the nearest 1/4" I can spare. From the trunk floor up to the rear deck brace, and between the trunk arms. I was aiming for a flat amp rack, but I can rework that accordingly with the box. To avoid generating artificial limitations just let me know some dimensions (a lil bigger) that would be most convenient for you and I will use those.
Rmichael91 Posted February 2, 2013 Author Report Posted February 2, 2013 The most I can extend is the depth from 20". The height and width are to the nearest 1/4" I can spare. From the trunk floor up to the rear deck brace, and between the trunk arms. I was aiming for a flat amp rack, but I can rework that accordingly with the box. To avoid generating artificial limitations just let me know some dimensions (a lil bigger) that would be most convenient for you and I will use those. 18hx34wx22d, can push the depth to 24" but thats the deepest considering room for the battery bank and amp rack.
Joe X Posted February 2, 2013 Report Posted February 2, 2013 The most I can extend is the depth from 20". The height and width are to the nearest 1/4" I can spare. From the trunk floor up to the rear deck brace, and between the trunk arms. I was aiming for a flat amp rack, but I can rework that accordingly with the box. To avoid generating artificial limitations just let me know some dimensions (a lil bigger) that would be most convenient for you and I will use those. 18hx34wx22d, can push the depth to 24" but thats the deepest considering room for the battery bank and amp rack. Ok updated, took only 23"D and I think they would do ok setup like that, you are running a lot of power.
Rmichael91 Posted February 2, 2013 Author Report Posted February 2, 2013 Alright, what would the port's 45° width be? I'm keeping the amp tuned low for the first few months so they'll be far from their potential. Eventually I'll do competitions, but I'm not really chasing numbers right now. Down the road I'll be getting an suv, so then the fun will begin.
Joe X Posted February 2, 2013 Report Posted February 2, 2013 Ok so the size of the 45 inside the port depends on how you do the inner corner smoothing but any case the port width must stay the same at the turn, take a look at the following, here the inner corner was slanted: If you do it exactly like shown the witdh of the inside 45 would be around 4 1/4". Also all inner edges at both ends of the port should be rounded.
