Rmichael91 Posted January 31, 2013 Report Posted January 31, 2013 Alright been working different boxes out, atleast trying to. Some of em are still on paper, didn't really like the measurements and didn't save them in torres. But this is what I'm at right now. Trying to stay within the outter dimensions, granted myself about a 1/4" of clearance on all sides with the box dead centered. Then clean up the trunk with beauty panels. Building for 2 Skar ZVX 12d2s off a sk4500. Subs and port both firing rear into the trunk. Vehicles a 2008 Chevy Aveo. 12ft^3 trunk but gotta have room for everything lol. I'm trying to get the tuning down to 32hz, highest I'll be happy with is 34hz. Daily music, not really looking at competing. Anyone see any changes I could make to get the most out of the box? 18x34x20 are my max dimensions (hxwxd)
taylorpro Posted January 31, 2013 Report Posted January 31, 2013 way too little port area. "port area per foot" should be up in the 12-16 range. Other than that, it looks good 1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
Rmichael91 Posted February 1, 2013 Author Report Posted February 1, 2013 Bump. Anyone? I'm just trying to do the build right the first time.
Tarball Posted February 1, 2013 Report Posted February 1, 2013 can you mount the subz inverted ? Also, running them off of a 4500, doint you want your box volume lower ? CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Rmichael91 Posted February 1, 2013 Author Report Posted February 1, 2013 can you mount the subz inverted ? Also, running them off of a 4500, doint you want your box volume lower ? Reasoning why? I know it'd add a little to the volume removing the displacement.
Tarball Posted February 1, 2013 Report Posted February 1, 2013 can you mount the subz inverted ? Also, running them off of a 4500, doint you want your box volume lower ? Reasoning why? I know it'd add a little to the volume removing the displacement. First question was to add a little to box volume. would buy you about 1hz towards your goal of 32hz tuning. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Rmichael91 Posted February 1, 2013 Author Report Posted February 1, 2013 I'm completely new to the whole box building aspect. That's why I threw it up here to get some input and possible changes.
levee000 Posted February 2, 2013 Report Posted February 2, 2013 Im doing the same setup so this gives my insight 2008 Yukon 2-18"s EVILS TEAM SSA TEAM AUDIOTEX
Raptorman Posted February 2, 2013 Report Posted February 2, 2013 They will be fine in 4.4 cubes on 4500. Box looks fine, just see if you can squeeze in at least 14 sq in per. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
