ChevyBoy95 Posted February 2, 2013 Author Report Posted February 2, 2013 reason between the 2 18s and 3 15s is i can fit both, 2 18s is cheaper, and when i sell my XLs (decently soon), i will be upgrading. Still undecided, will be around 1300 for 3 15s when i upgrade or 900 ish for 18s. major reason behind difficulty is im trying to stay under the window line so i dont get put in a different class when i start competing. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
pa-pa-platypus Posted February 2, 2013 Report Posted February 2, 2013 ok my bad didn't read the whole first post i apologize.. i think you can still make subs forward port up work.. but subs and port up could also work.. its tough to determine which would louder exactly..and i have a single cab f-150 and mine is subs up port to the side which could also be an option for you lol This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
mrd6 Posted February 2, 2013 Report Posted February 2, 2013 You have a NBS Chevy full-size don't you? Are there enough guys that have gotten loud in one yet to make the determination which setup meters best? I always though the full-size benefited from subs and port up to passenger side. This is generally what I have seen to work the best My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
ChevyBoy95 Posted February 2, 2013 Author Report Posted February 2, 2013 Kind of a useless thread on my part, for the sake of having a box i know will perform, ill stick with the 3 15s idea. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
pa-pa-platypus Posted February 2, 2013 Report Posted February 2, 2013 2 18's can work man lol there just isn't a cut n clear best box you can use thats going to get the loudest.. if nothing else build a few and find out This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
01 S-10 Posted February 2, 2013 Report Posted February 2, 2013 So far in my S-10 subs up/port up on driver's side has been the loudest. My new box will be subs forward/port up on driver's side, I'm thinking it will be louder with subs forward but we'll see TDH FTW !!!
ChevyBoy95 Posted February 2, 2013 Author Report Posted February 2, 2013 2 18's can work man lol there just isn't a cut n clear best box you can use thats going to get the loudest.. if nothing else build a few and find out but there is more of a reasoning, i will be doing 3 XL 15s, so i could just upgrade subs and direct swap, done deal. If i did 18s, i would have to pull it out, build a new box, get 18s, and be unsure on the result... i like the 3 15s thing too, it is different. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
CleanSierra Posted February 2, 2013 Report Posted February 2, 2013 I agree, box building is fun and not terribly expensive for just MDF(for a trial run at least). I think first configuration I would try is subs up, port up to passenger side. Im not the one you want to try to troll. Just a fyi for you.
01 S-10 Posted February 2, 2013 Report Posted February 2, 2013 I agree, box building is fun and not terribly expensive for just MDF(for a trial run at least). I think first configuration I would try is subs up, port up to passenger side. I've tried port on passenger side, it was a much lower score on the meter vs driver's side TDH FTW !!!
