jmsonoma03 Posted February 3, 2013 Report Posted February 3, 2013 does it have the ford sync? if so you might need a special harness.
skittlesRgood Posted February 3, 2013 Report Posted February 3, 2013 sounds like the switched 12v isnt hooked up. should be a red wire, not yellow. yellow is constant 12v. HUs usually show some life when they get power then shut off, like you describe. so that sounds normal. but the unit wont turn on without the switched power. just like it wont power on with the car off. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
CleanSierra Posted February 3, 2013 Report Posted February 3, 2013 It's the 12 volt switched I believe as well, just as I suspected earlier. Im not the one you want to try to troll. Just a fyi for you.
purplesyrup Posted February 3, 2013 Author Report Posted February 3, 2013 OK, Im getting ready to tackle this, thanks for the help, The 12V switched, red wire is hooked up in the harness, so the best way to do this is to run a hot wire, and put a switch on it?
purplesyrup Posted February 3, 2013 Author Report Posted February 3, 2013 I wonder why the red switched wire would not work on the harness, it had been a while since ive done this, but i have never had to worry about skipping some wires on the harness and running them elsewhere, except the remote wire of coarse
cloud77 Posted February 3, 2013 Report Posted February 3, 2013 You don't need a switch to the new 12v constant, It will just allow your radio to turn on while car is off. So make sure you turn it off when you want it off. Did you do this? 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
purplesyrup Posted February 3, 2013 Author Report Posted February 3, 2013 Well, some people say its the switched 12v, others say its the constant, I will try both and see if I can figure this out, my car does not have sync as someone stated earlier, Im going to start working on it in a few minutes
purplesyrup Posted February 3, 2013 Author Report Posted February 3, 2013 Im ready for this thing to quit BSing me, I got a clamp and dmm so I can clamp test my amp at different hz to figure out my box rise at the higher hz
kandiman71874 Posted February 3, 2013 Report Posted February 3, 2013 find a battery, twist the red and yellow together on the head unit, hook the wires to the battery correctly including the ground to the headunit and power the damn thing on. Simple test like that will tell you if its a head unit problem or a harness/vehicle conflict. Daily Driver 1999 Kia Sephia Kenwood DNX-893s Audison Bit One Processor 2 Dat 4.125's Sundown Audio SCV-6k Hertz hsk-165xl's Mids running active Focal V30 Series Tweeters running active Sundown Sa-8 v1's in the doors 2 Sundown Zv5 12's Lots of Hushmat Big 3+ and 3 + & 3- runs of Trystar 2/0 2 Dc Power Engineering 320 HP Alts 2017 Comp Vehicle 2006 Toyota 4 Runner Kenwood Excelon DNX-893s Audison Bit One HD DSP 4 Sundown Sa 6.5v2 Component Sets Focal Access 6.5 2 ways Sundown Audio Sax-50.4 Sundown Audio Sax-100.4 2 Dc Power 370xp Northstar agm27f Northstar agm65 2 Northstar asmagm 480's 2 Dual 1 Sundown Nightshade v3 12's 2 Sundown SCV-7500's All SMD Fuse Holders Shitload Of Sundown 1/0 120 sq ft Second Skin Damp Pro No, Its Not A Burp Truck!!!! 2016 Season 3rd place in Xtreme 1 At Finals 2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations) 2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL David said: audio is a lifestyle, not a hobby newls1 I cant read a tape to save my life... 1/2's are ok, but other marks confuse me kingsuv only men who cant read a tape, take it in the ass kingsuv you sir, get a pink hard hat on jobsites
Guest Posted February 3, 2013 Report Posted February 3, 2013 find a battery, twist the red and yellow together on the head unit, hook the wires to the battery correctly including the ground to the headunit and power the damn thing on. Simple test like that will tell you if its a head unit problem or a harness/vehicle conflict. this. all other responses are useless
