ehall8702 Posted February 4, 2013 Report Posted February 4, 2013 heres the dilema, i have a set of Boston Pr 5.5LF woofers, a set of MB Quart woofers, a set of JBL tweeters, a set of MB Quart tweeters, and a set of Polk DB tweeters. All of which were a component set at one time. Problem is i only have the JBL X-overs. Im not worried about the woofers because they will bepoered by channel 1&2 of my Kenwood channel ( 75x4@4 i believe). i an set HPF around 65 and be good there. Problem is the tweeters, i want to run atlest 4 of the 6 i have off of the amp. can i use the JBL x-overs and hook up 2 tweeters per x=over wired to 8ohm? will that run fine without cooking my tweets or x-overs? I plan on adding active x-over system so i can tweak everything before it hits te aps but wanna use what i gave for now too! i will also be adding another 2 channel amp dedicated just to twees and use 2 channels of my 4 channel and makea 3 way front stage.................eventually 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
Sonic Posted February 4, 2013 Report Posted February 4, 2013 My advice would to use the jbl tweters on the jbl crossover until you go active and stream line your front stage.
ehall8702 Posted February 4, 2013 Author Report Posted February 4, 2013 im greedy though! 6 tweets and only using 2 is gonna drive me nuts! lol i dont mind the polks running off of the H/U im looking for a 4 way active x-over but prices are crazy. i really wantr one that lets me control both the low and high cut off instead of just the HPF. i might end up building my own because eventually i want a full 3 or 4 way front stage any ideas on a x-over that would fit my plans and NOT cost a small fortune? 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
Omega5002 Posted February 4, 2013 Report Posted February 4, 2013 A famous term from SQ guys "Less is more" 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Sonic Posted February 4, 2013 Report Posted February 4, 2013 im greedy though! 6 tweets and only using 2 is gonna drive me nuts! lol i dont mind the polks running off of the H/U im looking for a 4 way active x-over but prices are crazy. i really wantr one that lets me control both the low and high cut off instead of just the HPF. i might end up building my own because eventually i want a full 3 or 4 way front stage any ideas on a x-over that would fit my plans and NOT cost a small fortune? Mini Dsp's.
White Lightning Posted February 4, 2013 Report Posted February 4, 2013 A famous term from SQ guys "Less is more" I will gladly take a pair of properly installed, powered, and tuned tweeters over a multiple tweeter setup any day !!! Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
ehall8702 Posted February 5, 2013 Author Report Posted February 5, 2013 im greedy though! 6 tweets and only using 2 is gonna drive me nuts! lol i dont mind the polks running off of the H/U im looking for a 4 way active x-over but prices are crazy. i really wantr one that lets me control both the low and high cut off instead of just the HPF. i might end up building my own because eventually i want a full 3 or 4 way front stage any ideas on a x-over that would fit my plans and NOT cost a small fortune? Mini Dsp's. may i ask whAT is a mini dsp and any links to where to get one? googled and ebay'd but no info as of yet 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
Sonic Posted February 5, 2013 Report Posted February 5, 2013 All info there http://www.minidsp.com/ Support and inquiry http://www.minidsp.com/forum/index
ehall8702 Posted February 6, 2013 Author Report Posted February 6, 2013 thank yall for the info and input...i will start researching and figure shit 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
