0db louder then -db tracks..?
If you play with audacity, frequencies of digital music files are measured in -db's, with zero being the highest. If you play the 0db track, that means any song you play will not reach 1% thd unless it's +db's, use -5db, then any song that is under -5db will not reach 1% thd, go at like -4db, then you reached passed 1% thd. Same applies with -10 db and -15db, most rap music I see usually is around -10 db, Psyph Morrison reaches to -5db, and test tones are at 0db.
Here's a good picture explaining what I mean
Young Jeezy - White Girl, 32hz is at -9.6 db, which makes you stay under 1% thd with the -5 tracks, but with the -10 db and -15db tracks, you'll be passing 1% thd
The 0db track is a loudest track than the others so it makes you set your gains the lowest out of the other tracks. -15db is the quietest track, meaning it'll make you set your gains higher.
I have experienced the opposite of that
That's weird, I don't understand, if you were to go through the tracks, without touching the gains or headunit volume, you notice the 0db tracks are way louder than -5db, -10db, -15db,etc
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
2004 Dodge Ram
Head unit- Alpine iDA-x305s
Sound processor- Clarion eqs746
Mids/Highs amp- Alpine MRV-F345
Sub Amp- Alpine MRD-M1005
Dash Speakers- (3) Dayton Audio rs75
Front Door- Skar SPX65c
Rear fill- Skar SPX tweters and Dayton ND140 midbass
Sub- Fi Audio SSD 15 high QTS
SHCA power/ground cables and Stinger interconnect
XS power D6500 under the hood and D680 in the amp rack
Big 3+ with SHCA
http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
In the DD1 instructions it says -5db will result in a louder system and the -15db will result in better sq.
You could not be more wrong. Go read your manual again.
I know i typed it backwards lol.
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
  • Who's Online   1 Member, 0 Anonymous, 491 Guests (See full list)
