12w7 enclosure question
Piggi3
3" port isn't enough. You'd risk chuffing. And what do you mean by having the sub load into the port?
I know Piggi isn't running much power, but don't make the box TOO big. You will lose back pressure against the sub and higher notes will suffer
from my exp ( not with jl though) being at about 16" of port made my boxes peaky around tuning i would suggest closer to 14" per cuft. should give better freq response. and you more along the lines of want the sub as far away from the port opening on the inside of the box. ive been told having the sub to close to the port opening can creat issues with it bottoming out or over excursion.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 1952 Guests (See full list)
