question about strapping and ohms
bass_stalker
me and my friend were having a discussion on strapping amps and we both came to the conclusion that we dont know shit about how that affects the final ohm load.
i was under the impression that it halfs the ohm load, so if i had two d2's wired to .5ohm each amp would be seeing .25ohm. am i wrong?
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Your correct. Try not to strap at .5 nominal .... That's pretty low for most people
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Strapping 2 amps is exacty the same as bridging a single 2ch amp into a mono amp.
When two amps are strapped, one amp is out of phase with the other thusly doubling your final voltage across the load.
Same rules apply as they would when bridging the 2ch amp.
The lowest rated impedance of the channel or amp should be doubled when bridging/strapping.
Example 2ch amp specs:
100W x 2 @ 4ohms
200W x 2 @ 2ohms (lowest)
400W x 1 @ 4ohms (lowest)
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
yeah i wouldnt personally strap an amp that low but there is no telling what he would do. i think he wanted to do two aq2200's on 4 15" hdc3 d2's
  • Who's Online   1 Member, 0 Anonymous, 1074 Guests (See full list)
