Need advice on Big 3
So I have a dilemma I have a lot of 4 gauge wire sitting in my garage and i can't really afford 0 gauge right now. Would it just be a waste of time and effort to do the big 3 in 4 gauge? Or should I just wait till I can get 0 gauge.
@therealweechaz
Id wait. It's really not that expensive.
1997 Trans Am WS6
Pioneer DEH-P5200HD
2 DC Level 4 M2 12s
4 cubes tuned to about 34hz
DC 3.5k
1/0 Welding Supply Ultra Flex
Stock 140A alt
Stinger Fuses & Fuse Holders
XS Power D5100
XS Power XP3000
Personally I would wait until I had the cash for 1/0. It would be a complete waist of time to do it now, then do it later. What you can do now is go get a string and measure out how much 1/0 you are going to need. Also figure out where you are going to run it (away from heat and moving parts, etc) But that's just me.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
alts up to like 150 amps will work fine with 4 gauge. you only really need to use 0 when you have 200+amp alts
double up your runs and do it in 4ga since you have a bunch of cable laying around. copper is copper.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
You could do 2-4 runs of 2ga and wrap the cables in a sleeve or somthing to make it look cleaner. Technically speaking it would be the same as if you had the 1/0 with enough copper..
still dont see why all of you guys are saying to double up 4 gauge or use 0 gauge when OP hasn't even stated how big the alt is.
If he had enough runs it should be fine from an electrical standpoint. copper is copper right?
whats the point if he has a 100 amp alt, to put 300 amp capable wire on it? it makes no difference compared to 4 gauge, other than OP wasting more money on shit he doesn't need to do.
but like i said, we cant say for sure unless OP (hopefully) comes back and states how big his alt is. and if he plans on upgrading it in the future.
  • Who's Online   0 Members, 0 Anonymous, 917 Guests (See full list)
