Quick Fusing Question
So i have 2 runs of 1/0 to a distro block then straight to a kx2500.1. should i use a 100amp fuse or 200amp fuse on each run. all the power wire is going to the amp and nothing else. I'm assuming the both wires are sharing the same load and I should go with 100amp but I'm just makin sure
1/0 gauge wire calls for a 300 amp fuse .......... so does that kick 2500.1
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 1419 Guests (See full list)
