how many batteries
You'll need a main battery and a secondary. Suggesting 2 d3100s. One under the hood, one in the rear. Do a run of 1/0 from the alt to the battery, as well as the remaining of the big 3. Run from the main battery to rear battery, with an inline fuse within a foot from the main battery under the hood. What size alternator do you have now? Slight possibility you can get away without a high output, but then there's the possibility of upgrades down the road.
If you use the general formula of 1 amp per 10 watts of power then you need at least 350 amps of alt and or a battery bank to supply the amp with, generally you'll want to exceed the power needed by 15% or more so voltage drop isn't too severe and cause you to drop to dangerous levels while playing full tilt.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
i have a stock alt right now, im in the process of collecting all my parts. got my sub my temp box ( until i can decide on the blow through setup) got the aq3500.
dam these xs d3100 are pricey eh..
im almost sure the 3100 bolts in my stock location as well..
do i have to have a 3100? or are there other size options?
You could use the XS Power search tool on the www.4xspower.com website, to the right of the page that'll load up what batteries would fit your vehicle. What do you drive?
  • Who's Online   0 Members, 0 Anonymous, 628 Guests (See full list)
