Mobileaudio25 Posted February 7, 2013 Report Posted February 7, 2013 I'm going to be installing 2 component sets running off a 4 channel amp. I don't really like bass coming through these components, if any minimal. What would be a good LPF setting? 130 hz? I'm running the components crossovers as well.
Kyblack76 Posted February 7, 2013 Report Posted February 7, 2013 Your a lil ass backwards. Set the HIGH pass. To what? Whatever floats your boat. At that point and UP, will be audible, and sent. Cheers. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Mobileaudio25 Posted February 7, 2013 Author Report Posted February 7, 2013 My amp has a flat, HPF and a LPF setting. So should I just set it HPF and completely ignore the LPF setting? Is that how it works? Sorry. This amp is an old school boss zedaudio
Quiet Posted February 7, 2013 Report Posted February 7, 2013 Hpf high pass filter Lpf low pass filter Lpf cuts out sound higher than set frequency Hpf cuts out sound lower than set frequency 2007 Pacifica Rebuild. Less quiet. Still not loud.
Kyblack76 Posted February 7, 2013 Report Posted February 7, 2013 10-4 You have 2 options. Run "FULL" and let your passive cross-overs do the work in passing bands, or, Run HIGH, AND ALSO use your passive crossovers. This would be used if you want to cut or remove even MORE lows from the comp set than the passive Xovers are going to do. Where do your passive Xovers start cutting at? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted February 7, 2013 Report Posted February 7, 2013 Errrrrrr, let try this, (if im losing you) What comp set? And ill look it up.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Quiet Posted February 7, 2013 Report Posted February 7, 2013 I'd say hpf components at 80, lpf subs at 80 then tweak from there to your liking. Each car has different acoustics. 2007 Pacifica Rebuild. Less quiet. Still not loud.
Mobileaudio25 Posted February 7, 2013 Author Report Posted February 7, 2013 I got it, thanks kylar. I'm going to run my amp on HPF and run my comps crossovers as well . I can do minor tweaking from there, thanks guys!
Kyblack76 Posted February 7, 2013 Report Posted February 7, 2013 I got it, thanks kylar. I'm going to run my amp on HPF and run my comps crossovers as well . I can do minor tweaking from there, thanks guys! Cool. Its Kyle. And not a problem. It can get a lil confusing. And you can cause damage with those being wrong, or off. So, ask. ask ask and then, ask. Glad you got it worked out, and learned something. And i see what you wanted to do. It will work well. Go get some work done. Cheers.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
