2000 Blazer Build, Zv.4's,NS-1, SHCA,XS Power, MECHMAN
Here are two ways I could go about wiring them.
I went ahead and did it this way, if it doesn't work it won't be near as hard to change it.
This will be where the two charge wires off the alts come to.
B7BB20F1-DBEB-4501-8BD0-2557D288D2CC-514
Second batt
FEF42ECD-5147-4106-93B1-ECF779BD7407-514
3rd batt. Gonna need some terminals for this one. 1 4/0 3 1/0 and 2 gauge on each terminal. Will be 2 4/0 grounds running to frame off this batt also.
14447CF8-29FF-497B-AD33-A04949E325CE-514
Better idea of how it's ran. Still gotta put interior plastics back in.
0DB546AF-EEDE-4F78-B19D-7A6D16878ACA-514
A4D5DCFA-382A-4326-BEFA-B9CFCECEF774-514
154204F8-68FB-40CE-AA80-5CA779FCD8E5-514
That's a lot of wire!
haha its only 4/0 man......i ALWAYS overkill my electrical. just how i am. id rather do a single run of this stuff then mess around with several runs of 1/0, and come out about as cheap. its only $3.61/ft
Got a little bit of a problem i gotta fix first before i install the alts. See how the charging posts stick out? im afraid it is going to hit the hood and the power steering pump. (left alt is the top). gonna send it off to singer to get them re-clocked and possibly powder-coated if he will. might even get a clamp of them since Mechman was too lazy to do so.lol
3530D527-2F11-4C92-B19F-6E8822491EAF-182
actually felt like i got a little bit acomplished today, was gonna send out the alts monday, but said screw it i'll test fit them even though i know they wont fit. i'll be damned if they fit lol
doesnt hit the hood, not even the insulation inside the hood. was rather shocked
5E9E8A8A-8DB4-4791-8E80-E78491202228-150
here is where i had to beat the fender in a little so the bottom alt would fit right.
647A6899-B10F-46D8-BC88-6F209E350CC0-150
1B1DD7C1-09DC-4FFA-BD7C-92AB386DB2FE-150
little bit of sub porn :)
CD3D1190-3681-4BAB-ADFF-05305F3B0264-150
B6774C86-9914-4477-B8CC-B91E491D4244-150
this is the plan on securing the subs down
A5F26A97-0270-4CCA-8999-08A571E27E7A-150
5960D6CC-A9B1-48B3-BCF3-DD0B90E44943-150
Hopefullly this weekend i get the wires ran for the alts, get everything under the hood done except grounds. plan on getting subs mounted and amp installed besides the power and ground( waiting on a distro block from toolmaker). also plan to figure out the tuning i want and might play around with some polyfill to see how it effects it.
Couple pieces of advice here since you are mounting the subs (if you haven't already by this point).
  1. Use stainless steel t-nuts
  2. While mounting glue the t-nuts in place with some rubberized CA glue (be sure not to CA the bolts to the t-nuts though!).
Looking good im tuned in!
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Why stainless steel t nuts? I have resined them before, but it was a headache. I put 3 coats of resin on the inside, so I won't have any problem with them slipping. Plus birch tends to help a little also in my experience lol
