CommonSyns Posted February 12, 2013 Report Posted February 12, 2013 this was a setup i used to have in my subaru legacy back in the day, just hook the leds into the speaker inputs on the amp, they wont blow well i never had an issue. pretty cool though. haha blue lights everywhere !http://www.youtube.com/watch?v=YRx6mtm-AbY That's basically what I did, But I hooked it up directly to the terminals on the subwoofer box. I never had a problem with them. Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed
BassHead88 Posted February 12, 2013 Report Posted February 12, 2013 this was a setup i used to have in my subaru legacy back in the day, just hook the leds into the speaker inputs on the amp, they wont blow well i never had an issue. pretty cool though. haha blue lights everywhere !http://www.youtube.com/watch?v=YRx6mtm-AbY That's basically what I did, But I hooked it up directly to the terminals on the subwoofer box. I never had a problem with them. thats great ! yup i looked at a video on how to do it and the guy was like yea just hook this up here and your good to go TEAM Northwest SPL TEAM SHOK
Wicks Posted February 12, 2013 Report Posted February 12, 2013 The best option is to get an LED controller. The LED strips have resistors built into them that are designed for 12v. Connecting to an amp output could pulse much higher voltage and damage the resistors/LEDs. Just because they initially work, it doesn't mean they aren't being damaged over time. Diodes usually fail "short" which is not good on a device that is not fused and directly connected to a high current supply (amplifier). LED controllers are cheap and give you lots of options for different pulsing patterns and adjustable brightness. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
BassHead88 Posted February 12, 2013 Report Posted February 12, 2013 The best option is to get an LED controller. The LED strips have resistors built into them that are designed for 12v. Connecting to an amp output could pulse much higher voltage and damage the resistors/LEDs. Just because they initially work, it doesn't mean they aren't being damaged over time. Diodes usually fail "short" which is not good on a device that is not fused and directly connected to a high current supply (amplifier). LED controllers are cheap and give you lots of options for different pulsing patterns and adjustable brightness. very true, i mean who knew if i kept them in there for ever on that initial setup, thanks for the explanation TEAM Northwest SPL TEAM SHOK
rusty959 Posted February 12, 2013 Report Posted February 12, 2013 Hooking up LEDs directly to your speaker terminals is like maxing out the gain because it "works" 2013 Subaru BRZ12" Orion HCCA on AQ 22001967 mustang restoration project: http://www.stevemeadedesigns.com/board/topic/110765-mustang-restoration-build-2011-edition/ Youtube: https://www.youtube.com/user/therusty959
CommonSyns Posted February 12, 2013 Report Posted February 12, 2013 Hooking up LEDs directly to your speaker terminals is like maxing out the gain because it "works" I don't understand? It worked for 4 years without any ill effects to anything to my system and the LEDs still work perfectly. Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed
Wicks Posted February 12, 2013 Report Posted February 12, 2013 The best option is to get an LED controller. The LED strips have resistors built into them that are designed for 12v. Connecting to an amp output could pulse much higher voltage and damage the resistors/LEDs. Just because they initially work, it doesn't mean they aren't being damaged over time. Diodes usually fail "short" which is not good on a device that is not fused and directly connected to a high current supply (amplifier). LED controllers are cheap and give you lots of options for different pulsing patterns and adjustable brightness. very true, i mean who knew if i kept them in there for ever on that initial setup, thanks for the explanation Sure thing. I'm not saying that directly connecting to an amp is always a bad thing. Depends on the internal voltage rails of the amp. Some smaller amps may work fine, but larger ones could be trouble. Another thing to remember is that an amp outputs an AC signal. LEDs (diodes) only conduct in one direction so you're really only getting light on half your sound wave. A controller should react to a signal in both directions. Probly not a big deal as half-wave may be plenty of light but something to think about.... More to think about. LED controllers have either small microphones, audio jacks or both. Be careful with the little microphones if you mount them in close proximity to your sub-box. The higher SPL could damage the microphone. I had a controller that flaked out for that reason. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
CommonSyns Posted February 12, 2013 Report Posted February 12, 2013 The best option is to get an LED controller. The LED strips have resistors built into them that are designed for 12v. Connecting to an amp output could pulse much higher voltage and damage the resistors/LEDs. Just because they initially work, it doesn't mean they aren't being damaged over time. Diodes usually fail "short" which is not good on a device that is not fused and directly connected to a high current supply (amplifier). LED controllers are cheap and give you lots of options for different pulsing patterns and adjustable brightness. very true, i mean who knew if i kept them in there for ever on that initial setup, thanks for the explanation Sure thing. I'm not saying that directly connecting to an amp is always a bad thing. Depends on the internal voltage rails of the amp. Some smaller amps may work fine, but larger ones could be trouble. Another thing to remember is that an amp outputs an AC signal. LEDs (diodes) only conduct in one direction so you're really only getting light on half your sound wave. A controller should react to a signal in both directions. Probly not a big deal as half-wave may be plenty of light but something to think about.... More to think about. LED controllers have either small microphones, audio jacks or both. Be careful with the little microphones if you mount them in close proximity to your sub-box. The higher SPL could damage the microphone. I had a controller that flaked out for that reason. Is it just any LED controller? I would like to add more LEDs to my new system I am getting, But as you said it may create problems later on. I only used the 2 led pods on a Alpine Mrp-1000 at 2 ohms. The new system will be substantially bigger than what I had. Any chance on a link? If you could also direct me to some LEDs that would pulse that would be good also. Skar Audio SDR 10" x2 (Sealed Box) Skar Audio 1500.1D (1 Ohm) x1 Skar Audio TX525c (Front with dash tweeter) x1 Kenwood Excelon KFC-X173 (Rear Coax) x1 JL Audio 360.4 (Mids & Highs Amp) x1 DEH80-PRS XS Power d3400 Singer Alternator 275A 98 Jeep TJ 4.0 5 Speed
bassfreake Posted February 12, 2013 Report Posted February 12, 2013 this was a setup i used to have in my subaru legacy back in the day, just hook the leds into the speaker inputs on the amp, they wont blow well i never had an issue. pretty cool though. haha blue lights everywhere !http://www.youtube.com/watch?v=YRx6mtm-AbY lol dude that's freakin epic!! I totally want to do that with my car in blue like that but somehow I feel like doing the interior lights of my car in bright ass blue when my car is red would just be weird lol Thanks I was pretty excited about the alt myself. kind of like a school girl, in a dress, on a swing. lol It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out. My Build Log
BassHead88 Posted February 12, 2013 Report Posted February 12, 2013 this was a setup i used to have in my subaru legacy back in the day, just hook the leds into the speaker inputs on the amp, they wont blow well i never had an issue. pretty cool though. haha blue lights everywhere !http://www.youtube.com/watch?v=YRx6mtm-AbY lol dude that's freakin epic!! I totally want to do that with my car in blue like that but somehow I feel like doing the interior lights of my car in bright ass blue when my car is red would just be weird lol dude thanks , i kinda went through a LED light phase if you will. haha had them for awhile then pulled them all out, one time i hooked all the lights up lol rave show in my car while i was driving haha, man i miss this though, good times TEAM Northwest SPL TEAM SHOK
