99xtremedime Posted February 13, 2013 Report Share Posted February 13, 2013 Need someone who really knows there shit when it comes to box designing. I can send money via PayPal just lmk the amount. I am walling my 99 xtreme with 4 Skar VVX-15's D4 ohm on a Crescendo 3KWP @ .5. Just looking for a nasty, air moving ground pounder than can get low and murder the low lows, yet still be as musical as possible with those throat tickling high notes. My max dimensions give right at 13.5 cubic feet before anything. I can get more if need be but I have read that on this power the VVX's tend to like smaller enclosures. With seat configuration it has to be like in the picture I sketched up. Subs forward, port forward at the top. Lmk if you can help me! -2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's -AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt -Knu Konceptz Wire Link to comment Share on other sites More sharing options...
99xtremedime Posted February 13, 2013 Author Report Share Posted February 13, 2013 Oh, and forgot to add, would like to have the design by Saturday. It is the only time I have to build between now and SBN. And I really wanna have this thing playing by then. -2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's -AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt -Knu Konceptz Wire Link to comment Share on other sites More sharing options...
AMI CUSTOMS Posted February 13, 2013 Report Share Posted February 13, 2013 If it has to be that layout like that, do the port the full length of the top of the wall, and do your width of the port in the ratio you need for proper port area, i have never messed with Skar woofers so can't comment, but I would assume 16 sq inch per cube is the area you want and tune around 35 hz for ground pounded and move air. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty Link to comment Share on other sites More sharing options...
99xtremedime Posted February 13, 2013 Author Report Share Posted February 13, 2013 See, that is the part that I'm not so hot at. I really haven't ever been able to get the tuning the port thing down all that well. -2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's -AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt -Knu Konceptz Wire Link to comment Share on other sites More sharing options...
Joe X Posted February 13, 2013 Report Share Posted February 13, 2013 Once you take away displacements from the above it ends up being tight, tight. Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 13, 2013 Report Share Posted February 13, 2013 i hate port on top. your roof is the weakest structural panel and you want to stick the most violent part that close? THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
99xtremedime Posted February 13, 2013 Author Report Share Posted February 13, 2013 Well it's really the only place that there is room for a port. If I put it on driver or passenger side, the seats will choke out the port. If I do center slot, half will be choked out by the center console. -2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's -AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt -Knu Konceptz Wire Link to comment Share on other sites More sharing options...
99xtremedime Posted February 13, 2013 Author Report Share Posted February 13, 2013 Once you take away displacements from the above it ends up being tight, tight. Like I said, I can definitely get more space. There is still 2-3 cubes I can get, but it makes for more angles so its a little more complicated. -2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's -AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt -Knu Konceptz Wire Link to comment Share on other sites More sharing options...
99xtremedime Posted February 13, 2013 Author Report Share Posted February 13, 2013 i hate port on top. your roof is the weakest structural panel and you want to stick the most violent part that close? It's not that I want to, it's that with how close my seats will be to the box, I sorta kinda have to. -2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's -AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt -Knu Konceptz Wire Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 13, 2013 Report Share Posted February 13, 2013 heres the thing. The roof flap is going to kill you too. You just have to figure out whats gonna kill you more. i did subs pass side port drivers. I would rather deal with the seats that can move being a problem then the roof that only moves if it rips. thats my take on it. I cant recall seeing guys who are stupid loud doing a top port. There might be some but none that I can remember. besides port on the drivers side means you can stuff some assholes head in the port if you need to THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
