Peyton Cole Posted February 13, 2013 Report Posted February 13, 2013 setup jensen vm9215bt..plan to replace asap with the new jvc kwav61bt doubledin rockfordfosgate tweeters and factory tweeters ran through head unit 2kicker 6x9 2kicker6.5 on jvc 4 channel amp(not sure of watts)..mids and highs sound fine 2alpine mrp500watt 2 channel mono amplifiers now here's the issue i've ran through a couple of Memphis subs over the past 2 weeks and no matter what happens they continue to sound like shit after three or four days..first i had ordered some pr15s which i read to be 500w rms which i now realize that isnt the case the pair is 500 not the individual speaker.. anyway these speakers blew pretty much asap and didn't get hardly any volume for a day or two then just quit coming on all together. so i decided to step it up and i ordered a old school mojo and i ordered another one to appear to look the same but turned out to be an M3. all sounded well with these subs for the first few days but now when a bass note hits they just drag out and sound like shit. not to mention the dustcap blew off of the mojo on the way home after having it hooked up for the first time idk if that matters or not. as well i never turned the bass up on my head-unit above 0 and i am not using a bass booster of any kind and everything was professionally installed or at least i think. what are some good subs i can get that will utilize my amps that wont crap out on me in just a couple of days?? Team CNGraphix 2013 sonata Dc power 320 alt 3 kinetik 3 shuriken All knue and sky high wiring Dd m3b x2 Rockford 1000-4 2 fi sp4 18 4 vo 6.5 4 nendo pwx8 6soundqubed tweets 2 b1 tweets Pioneer avh4500 hu
WastedTalent Posted February 13, 2013 Report Posted February 13, 2013 Anything reputable. But to me, sounds like crap install if they put 500 watts to each sub if the PAIR is 500 watts. I'd take it somewhere else man. Sheena = pedobear
OG BudBone Posted February 13, 2013 Report Posted February 13, 2013 Installer probably clipped the hell out of em 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000
Ryan_H Posted February 13, 2013 Report Posted February 13, 2013 Some thing does'nt sound right hear on the install part
Antonio Moore Posted February 13, 2013 Report Posted February 13, 2013 Sounds like u bought some bad subs u did mention ordering old school(used) online. Wasn't a good idea no telling how bad they were treated before u used them
kirill007 Posted February 13, 2013 Report Posted February 13, 2013 Show us a picture of the settings on the amp and headunit first and tell us at what volume you play it. Thinking is the root of all problems... You ALWAYS get what you pay for.
Antonio Moore Posted February 13, 2013 Report Posted February 13, 2013 Either way u need new subs how much are u trying to spend on
95legwagon Posted February 16, 2013 Report Posted February 16, 2013 to be honest......the cap is probably doing more harm then good. arent those batteries agm? and your starting battery is lead acid? shouldnt mix the 2.....from what ive read. if your just replacing your starting battery with the kinetic then it should be fine. i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
