Joe X Posted February 14, 2013 Report Posted February 14, 2013 The physical port length is the number you enter in Torres "Port length" field and is measured along the center line end to end so in the following pic L1+L2 = what Torres shows: The field marked as "physical port length" as defined in Torres is found by adding the length of the port parts + 0.75
OG BudBone Posted February 14, 2013 Author Report Posted February 14, 2013 The physical port length is the number you enter in Torres "Port length" field and is measured along the center line end to end so in the following pic L1+L2 = what Torres shows: The field marked as "physical port length" as defined in Torres is found by adding the length of the port parts + 0.75 I think I might be understanding. Does that mean the port wall for each side would be 24 inches long? Maybe? Once again sorry guys 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000
Joe X Posted February 14, 2013 Report Posted February 14, 2013 Yes! the port area splits at the turn BUT it is not longer, each sub will see the same port length on either side.
OG BudBone Posted February 14, 2013 Author Report Posted February 14, 2013 Yes! the port area splits at the turn BUT it is not longer, each sub will see the same port length on either side. So the port width would be like 2.1 against the back wall then right? 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000
Joe X Posted February 14, 2013 Report Posted February 14, 2013 Thats's right the port area is split by halfing the width so 2.1", to figure out the length you still follow the center line after the turn despite being narrower as it can be seen in the figure.
OG BudBone Posted February 14, 2013 Author Report Posted February 14, 2013 Thats's right the port area is split by halfing the width so 2.1", to figure out the length you still follow the center line after the turn despite being narrower as it can be seen in the figure. Sooo would my port parts be 15.4 and 7.9? 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000
Joe X Posted February 14, 2013 Report Posted February 14, 2013 Here's what a cutlist with your box dimensions would look, port 29" long BUT port width 4.25" instead of 4.2": External Height = 15 inExternal Width = 41 inExternal Depth = 19 inPort Width = 4 1/4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 41 x 19Left & Right Sides = 17 1/2 x 12 3/42x Front = 18 3/8 x 12 3/4Back = 41 x 12 3/4Shared Port Internal Assembly Parts:2 x Front to Back = 15 3/8 x 12 3/42 x Extension = 8 15/16 x 12 3/4
OG BudBone Posted February 14, 2013 Author Report Posted February 14, 2013 Here's what a cutlist with your box dimensions would look, port 29" long BUT port width 4.25" instead of 4.2": External Height = 15 in External Width = 41 in External Depth = 19 in Port Width = 4 1/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 41 x 19 Left & Right Sides = 17 1/2 x 12 3/4 2x Front = 18 3/8 x 12 3/4 Back = 41 x 12 3/4 Shared Port Internal Assembly Parts: 2 x Front to Back = 15 3/8 x 12 3/4 2 x Extension = 8 15/16 x 12 3/4 Well I think Im gettin it now. Thank you very much for explaining it to me. Much appreciated. 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000
Joe X Posted February 14, 2013 Report Posted February 14, 2013 If I can help you further, let me know.
Torres Posted February 14, 2013 Report Posted February 14, 2013 joe you're right about the port length in your earlier post...but i think you mean 'effective port length' in the first part, instead of physical port length in both. just to clarify it so there's no confusion. i may want to add that in the title of it as well......
