12" Ported Enclosure [Build Log]
Taylor Matheson
Ok so here is a suggestion good to 800 WRMS per sub, port/subs aiming frontwards or backwards, recheck your max dims, dimensions below can changed:
Enclosure Specifications:
Fb = 34 Hz
Vb = 4 ft^3
External Height = 14 in
External Width = 39.5 in
External Depth = 21 in
Port Width = 4 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2x Front = 17 1/2 x 12 1/2
Back = 39 1/2 x 12 1/2
Left & Right Sides: 19 1/2 x 12 1/2
Top & Bottom = 39 1/2 x 21
Shared Port Internal Assembly Parts:
2 x Front to Back = 17 1/4 x 12 1/2
2 x Extension = 2 1/4 x 12 1/2
Assembly guide (generic dimensions):
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.
- The port needs 4 1/2" of free airspace in front of it for proper operation.
- Setting your amp's subsonic filter to 28Hz is suggested.
go for dual 2 ohms sundowns, find an amp that'll do good on .5ohm and upgrade your electrical
I plan on getting a sundown 1500D amp, along with the two speakers specified. I am not willing to spend shit tons of money on this as its my first sub system. Its simply a custom built one that I can call my own.
Fb = 34 Hz
Vb = 4 ft^3
Cut Sheet List:
This is insane? Did you just figure all this out for me or are you getting this off of some website?
Also, those are basically the max dimensions I am willing to use, considering that I need alittle space in the back... Its a shared vehicle for the time being... also took the height off of the second lowest point in the trunk so I could slide the box right to the back, doing this will allow me to fit the amp on top or behind the box (whichever I chose). And another thing the subs will be facing the trunk opening (I heard this is better for a ported sub box in the long run).
EDIT~ Thank you so much for the effort you put into this post. This forum is proving to have amazing posters. <3<3
Also the 45's measurements would be awesome, if I am going to make it ill make all
You're welcome Taylor, Ok, the 45s inside the port need to be done perfectly or not done at all, they should be done exactly as follows:
The important thing is that the 45s don't make the port narrower than 2 1/4" (in your case) to each side.
Also is important that you round the inner edges of the port at both ends as shown in the pic above.
If you have any questions let me know.
:bsflag: :bsflag: :bsflag: From noob´s for noob´s, stay with the D 4 and go 1 Ohm. The only amps i know who are doing 0.5 Ohm´s with waranty are some Lanzar
Opti model´s with lowest poweroutput on 0.5 Ohm is 2000 watt RMS and above. I never saw a clamptest of Lanzar Opti 0.5 Ohm stable amp´s. Here in the discription http://www.ebay.com/itm/Brand-New-Lanzar-OPTI2001D-2000-Watt-Monoblock-Class-D-OptiDrive-Power-Car-Amp-/310409837117?pt=Car_Amplifiers&hash=item4845de3a3d you can see that they are fused with 120 amp´s that means that they put arround 1200 watt´s @ 1 Ohm. This is a rule by thump math, and idk how the math is for 0.5 Ohm stability, and if it be possible/a logic math 120 amp´s for 2000 watt on 0.5 Ohm.
Go with a 1500 watt RMS amp, all the well known brand´s like Sundown, Skar are underrated and would put a little bit more out. But you can need the watt´s in case of the loosing in imprise. Your sub´s will sound more solid.
"in the abundance of water, the fool is thirsty" Bob Marley
Opti model´s with lowest poweroutput on 0.5 Ohm is 2000 watt RMS and above. I never saw a clamptest of Lanzar Opti 0.5 Ohm stable amp´s. Here in the picture
Well said! Stick with the D4 Sa's.
  • Who's Online   0 Members, 0 Anonymous, 1419 Guests (See full list)
