Misc. Sealed off trunk - '01Stratus *Gutted*
I would get some wood glue and saw dust pasted up in there and since you're planning on fiberglassing. Just resin over the top of it. Damn is the jacket cut all the way through?
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
No addiction here :lol2:
Ha, the AQ sub's surround smell like my car air freshener (black ice) lol
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
yupp all the way... which sucks. Gonna wrap the hell outta it with electrical tape and make sure it isn't pinched this time.
edit: would be a PITA to take that wire back through the great stuff foam just to run another wire or put some techflex on it :/
Box is glassed :D will need to do the braces tomorrow. It was my first time working with the stuff, and damn it sucked. Total pita but hopefully it'll b4 worth it.
Oh and stupid me. I assumed that resin could cure at 20 degrees.sorta but not good. So i had to put a space heater in there. Either way I'm happy with how it is. I'll update with pictures when I'm on computer.
First I wanted to get the bracing cut. Which had to be done in two pieces, because one would be a pita to get into position. so I cut 2 6" pieces (1 for each side) and then 7.5" and some change to see what all I had to shrink with. (inner height is 13.5") funny to find out the left side is like 1mm taller than the right lol. anyways got those figured out below.
I put down cardboard to make sure my carpet didn't get resin on it. I had a feeling shit was gonna get messy quick.
Glued the bracing next.
glass glass glass glass glass glass glass glass
that joint is terminated lol
Thank goodness I put down that cardboard lol
My original plan was to do all the joints, I even cut a strip for each one. well once I realized how much resin was used in that first strip I knew that wasn't going to happen. So then I just said screw it, did the most important ones (the top back) and then slapped on a ton of resin on all the sides and other joints.
tomorrow I'll do the bracing. Not sure how I'll got about it. (wrapping it width wise or length wise)
at least I now have a better handle on the nature of resin and mat.
which is close to pine sap and tissue paper lol
Nice work sir. Let me know if its any stronger :)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   0 Members, 0 Anonymous, 2479 Guests (See full list)
