2 fi ssd in a sealed 4.2 after displacement box and a t10001bd
due to my space limitations i might have to mount my amps to my box. i heard that wasnt goodto do?
what if i was to layer it with dynamat between the amp and the box would it be okay then
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
I read that everything inside the Rockford amps is screwed down so you should be just fine but I'm sure the dynamat wouldnt hurt
2000 Ford Explorer XLT
-20" RVM "Buck" Wheels
-2.5% Tint
-CompuStar Vizion Alarm
-(4) Infinity Kappa 680.7cs 5x7"
-1 XStatic BatCap Model 300
-2 18" DC LVL 4's
-Amps are undecided
thats good 2 hear im gonna throw some dynamat under it hopefully that wont hurt it
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
Thats not all true, gotFI's amp shook some parts loose and it fried :(
Yeah, it happens, I'm just trying to help out if he has to mount to the box.. I had to mount my amp to the top of the box in the Sausage, and it did shake loose (from the box) within a month.. Added some extra vertical bracing in the box, rubber grommets under the amp feet and under the screw heads. Holding strong since then.. Depending on the available space, you can attach the amp, but still isolate it from the vibration as much as possible..
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
check my build, i used the grommets the first time around. need to use some on both sides where you're puttin it. second time around i double layered the back side where the amps went, and put 6 layers of fatmat between the sheets of wood. the inside is braced nice and sexy on the inside also.
nice set-up! thats what im going to do for know but when it warms up im going to build into the sides of the trunk or a false floor cause i got to also find away to secure the box so it doesnt move around in the trunk
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
  • Who's Online   0 Members, 0 Anonymous, 2097 Guests (See full list)
