6.5" Rear Pods And Rca Coaxial Cable
I just purchased 2 sets of Clif Designs 60.4 Components and am completley redoing my system (last car DIED). I was wondering if it would be a good idea to build some type of enclosure around the mids mounted in the rear deck since my subs are locatde undeneath them. I dont want to blow the voice coil with my twelves. also is a blow thru that is 4.5" x 13" X .75" good enuff or should i open it up some more? I will try and post some pics as soon as I can.
my box is 3.832 cubes
Also I was wondering if it is possible to use coaxial (tv) cable to make rca cables???
My new system will consist of
4 - 6.5" clif designs 60.4
4 - 28mm tweets
2 - 12" kicker Comps 4 ohm
1 - Com1 Command Center 6 Channel Amp
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
Guest MegaloManiac
a coaxil from a tv is only a single conductor. you need 2 conductors for 1 rca. However you can ground the shield for the neg. I dont suggest using coaxil cable due to if they get kinked they are damaged for good, they also are not as flexible. If you really serious about wanting to make your own cable checkout http://www.fullcompass.com/category/Single-Audio-Cable.html , they sell conductor wire fairly cheap.
  • 4 months later...
update? ever get your compo in? was thinking about getting some just want to know how they sound.
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
