Dylan Mohammed Posted February 19, 2013 Report Posted February 19, 2013 Not sure if posting in the right section but, im about to buy a RE Audio DTS 1000 to power a D4 Alpint type R 12, and I dont know what the bass freq. knob is for. Is it for the sub to play at that freq? Here is a picture. http://www.sonicelectronix.com/pictures_new.php?id=32465&picture_id=648790
Dylan Mohammed Posted February 19, 2013 Author Report Posted February 19, 2013 So would i also set the lpf to 80 also?
DubNDodge Posted February 19, 2013 Report Posted February 19, 2013 it just sets where the frequencies will stop at. if you buy it set that to 80. and the sub frequencie to 30 That is LPF, you set that to 80 as a general rule of thumb. The subsonic to 30, or half octave below the tuning of your port. He was asking about the bass freq. That is normally the frequency the bass boost will boost. Even though it says in the description that is already set to 45hz. So I'm not entirely sure what the bass freq is. In order to correctly tune you amp, you need to use an oscilloscope or a dd.1. Tuning it by dmm or by ear is not the best way to tune your amp. Oh, and NEVER use bass boost. period. Only use the gain when tuning the amp. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Dylan Mohammed Posted February 19, 2013 Author Report Posted February 19, 2013 OK, thanks for the help, and quick replys
naughtyca Posted February 19, 2013 Report Posted February 19, 2013 keep the settings on the picture and just throttle down the bass boost to zero or set it to 1 or 2 very little bass boost if possible
Raptorman Posted February 19, 2013 Report Posted February 19, 2013 A DMM will suffice, you dont NEED a dd1 or oscope, although they are the better options. Also bass boost needs to be at zero, any eq's nee to be off too. No bass boost from the head unit or anything like that. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
