SmoTtPokeR420 Posted February 20, 2013 Report Posted February 20, 2013 whats up yall, i have a kenwood 1800watt runnin 2 l7 15s in a probox. i have 0 gauge power wire, havent upgraded all the wire yet, nor the big 3, as i am waiting on my new amp to come in tomorrow. but ive been having a problem with my current amp, as i play music loud for about 30 seconds the amp seems to reduce the power being sent to the sub. the amp does not shut off, just makes the sub get quiet. im hoping its just a messed up amp and this new one doesnt do the same thing. but i wanna know what could be causing it just in case the problem continues with my new amp. i have a stock alternator but i went and bought a duralast gold battery recently..if that helps any. 2005 Lincoln Aviator Pioneer AppRadio2 1/0 gauge wiring Soundstream TX1.2000 2 Kicker L7 15'' subs 9 cu.ft. Dual Ported Super Bass ProBox 4.5 cu.ft. per sub
321slapinbass Posted February 20, 2013 Report Posted February 20, 2013 its called voltage drop. it takes power to make power. 2000 Dodge Durango Subs - (2) SKAR VVX 15 D2's Box - 7.2 ft^3 @ 33hz, 120 in of port Sub amp - Digital Designs M2 @ .5 ohm Mids + Highs - PRV Audio Mids + Highs amp - Hifonics 2000.4 Headunit - Alpine CDE-100 Equalizer - Clarion EQS746 Batteries - Mopar group 27 + (2) C&D 52ah Wiring - 1/0 BIG 3, (2) runs 1/0 Alternator - Singer 250A 147.79 dB @ 35hz - burp - sealed on dash 147.47 dB @ 35hz - music - sealed on dash YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
SmoTtPokeR420 Posted February 20, 2013 Author Report Posted February 20, 2013 yeah i know about the whole watts thing, and im upgrading the big 3 this weekend after i get my amp, so hopefully that helps. im thinking its just the amp, because i had it on just one of the 15s and it would do it too, it just took longer for it to happen.. 2005 Lincoln Aviator Pioneer AppRadio2 1/0 gauge wiring Soundstream TX1.2000 2 Kicker L7 15'' subs 9 cu.ft. Dual Ported Super Bass ProBox 4.5 cu.ft. per sub
SmoTtPokeR420 Posted February 20, 2013 Author Report Posted February 20, 2013 my voltage stays over 14v so im assuming its not that. maybe a soldering wire in the amp came loose or something. after i install new amp and re run all my wires and upgrade the big 3 ill post back on here and let yall know if the new amp fixed it or if im still havin the same problem. 2005 Lincoln Aviator Pioneer AppRadio2 1/0 gauge wiring Soundstream TX1.2000 2 Kicker L7 15'' subs 9 cu.ft. Dual Ported Super Bass ProBox 4.5 cu.ft. per sub
D-train-13k Posted February 20, 2013 Report Posted February 20, 2013 my voltage stays over 14v so im assuming its not that. maybe a soldering wire in the amp came loose or something. after i install new amp and re run all my wires and upgrade the big 3 ill post back on here and let yall know if the new amp fixed it or if im still havin the same problem. how are you measuring your voltage? a dmm? The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
SmoTtPokeR420 Posted February 20, 2013 Author Report Posted February 20, 2013 i have one of the stinger voltage meters. ive been told its an internal problem and a new amp should fix it. so i got my fingers crossed. i hate havin a pretty decent set up that doesnt sound anywhere near what it should. 2005 Lincoln Aviator Pioneer AppRadio2 1/0 gauge wiring Soundstream TX1.2000 2 Kicker L7 15'' subs 9 cu.ft. Dual Ported Super Bass ProBox 4.5 cu.ft. per sub
Swordlordboy1234 Posted February 20, 2013 Report Posted February 20, 2013 i have one of the stinger voltage meters. ive been told its an internal problem and a new amp should fix it. so i got my fingers crossed. i hate havin a pretty decent set up that doesnt sound anywhere near what it should. He said the S word My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
SmoTtPokeR420 Posted February 20, 2013 Author Report Posted February 20, 2013 lol like i said, decent system..its no steve meade or neil barber, but i can only spend what my bank account will let me haha. 2005 Lincoln Aviator Pioneer AppRadio2 1/0 gauge wiring Soundstream TX1.2000 2 Kicker L7 15'' subs 9 cu.ft. Dual Ported Super Bass ProBox 4.5 cu.ft. per sub
Agreene Posted February 20, 2013 Report Posted February 20, 2013 it may be the wire from your amp to your subs what size wiring you have there , as you turn your music up that wire may not be to support it causing clipping which the amps picks up and protects itself.
Agreene Posted February 20, 2013 Report Posted February 20, 2013 good ofc 12 gauge is only good for 1k watts thats a problem.
