AmmoJammo Posted March 3, 2013 Author Report Posted March 3, 2013 link seems to have broken? I assume its shunts on the negative rail, measuring the voltage drop across them.
__d_a_v_i_d__ Posted March 3, 2013 Report Posted March 3, 2013 Example 2.Amplifier with the maximum power of 100W for the load of 4Ohm. Maximum output current there will be 5A (P=I^2*R). With the work to 4Ohm the protection will operate at the power of 100W, with 8Ohm of current overload simply it will not be, with 2Ohm the protection will operate at the power of 50W, i.e., it is accurate at the moment of the overload of amplifier. But if amplifier is not calculated for the two-ohm load, then neither the total nor exceeded power from the amplifier to remove will come out. Failure of amplifier is improbable. The elements of current protection most frequently are connected into the emitter or discharge circuits of output transistors. With the appearance of current overload the protection locks output transistors, limiting output current. This is sufficiently effective and is reliable, if amplifier is executed on the discrete elements, t to the elements of protection are immune to heating from the heat-releasing components, and their operating conditions practically do not change. But if amplifier integral (microcircuit), then there are no these elements either or they are subjected to general heating together with the crystal of microcircuit, and the stabilization of the modes of operation of these elements is hindered. It is completely possible that these elements are disposed to the wear and tear with the maximum permissible values of the output current, when microcircuit works on the limit. By these, I think, it is possible to explain the frequent failures of integral amplifiers, and the, as a result, extended opinion about their unreliability. Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
AMI CUSTOMS Posted March 3, 2013 Report Posted March 3, 2013 Ninja'd TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
CHINO11550 Posted March 3, 2013 Report Posted March 3, 2013 i have the same amps with a lot more batts & big alt & mine would shut off when they were strapped @ .5 each...1ohm both...but when i unstrapped them they stopped protecting H/U Pioneer deh80prs w/ HRT iStreamer Ipod DACFront stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweetsamp running 4mids, Mosconi Audio 300.2amp running 8tit & alum tweets, Mosconi Audio 200.28 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'zbox is a 4th order band passbatts. 1 XS Power D3400 under hood,6 D3100 in back2 XP 370 amp DC Power alts.MLA module 15+voltsAll in a 97 2door Tahoe LT2010 West Coast Reg. 140-149.9 Bass Race Champ Team Bass Hz
AmmoJammo Posted March 3, 2013 Author Report Posted March 3, 2013 i have the same amps with a lot more batts & big alt & mine would shut off when they were strapped @ .5 each...1ohm both...but when i unstrapped them they stopped protecting but of course you never would have tried it with less batteries, because no one removes batteries once they're added you only realise the issue when you start off with less batteries, and try adding more... I take it you came to the conclusion that it was the short circuit protection coming in to play?
AMI CUSTOMS Posted March 3, 2013 Report Posted March 3, 2013 i have the same amps with a lot more batts & big alt & mine would shut off when they were strapped @ .5 each...1ohm both...but when i unstrapped them they stopped protecting but of course you never would have tried it with less batteries, because no one removes batteries once they're added you only realise the issue when you start off with less batteries, and try adding more... I take it you came to the conclusion that it was the short circuit protection coming in to play? Seriously stop saying that, it is the most dumbass comment in this whole discussion. It makes no sense what so ever. You are looking at this from the complete opposite point of view, you are so far out in left field that I don't even know if you can come back to play ball. Comments like this confuse the hell out of new forum members cuz they get the complete wrong idea. What you are saying is so wrong I need like a triple face palm....... TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
AmmoJammo Posted March 3, 2013 Author Report Posted March 3, 2013 lolz so, anyway, once the car is fixed, I'll measure voltage drop, not that it will tell me why the amps are more prone to protect with more voltage.
AMI CUSTOMS Posted March 3, 2013 Report Posted March 3, 2013 lolz so, anyway, once the car is fixed, I'll measure voltage drop, not that it will tell me why the amps are more prone to protect with more voltage. Oh jeeze, voltage drop isn't the fucking problem!!!! It is the protection circuit because you have low ohm load!!!! I don't give a shit if you put 16 volts on that bitch it is still gonna protect due to ohm load. You do realize amps are more sensitive when strapped right? You understand what strapping is doing right? You are running the slave amp out of phase. Makes the amp alot more sensitive to circuit protection. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
AmmoJammo Posted March 3, 2013 Author Report Posted March 3, 2013 So why is it that more batteries/more charge results in the amps going in to protect more? that's what the question has been the whole time, and no one has been able to answer it.... amusing responses, but very uninformative.
DubNDodge Posted March 4, 2013 Report Posted March 4, 2013 I know nothing about an amps internals, but what I gathered from this thread: A amplifier is set to make X power. If you go over X amount of power it will go into protect. If you have more voltage going to the amplifier(less voltage drop), the amp will produce more. Putting it over that X amount, putting it into protect. If you have less voltage going to the amplifier(more voltage drop), it won't be reaching that X amount, not going into protect. Am I correct or am I off? '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
