help wiring multipal runs
In my up coming build im planing to do a bunch of runs of 1/0 from my front to rear.....( at least 6 pos and neg). In my current car Ive got 2 runs off the alt to the front battery then 2 runs of positive and 2 runs of negative connecting the front batt to the rear bank. For my next build im adding way more power and I need to figure out the wiring mess! I was thinking to do 3 runs off alt to front batt then 3 to the rear bank. Then possibly 3 off the alternators to the rear bank to cover pos side. But for ground I dont think I can fit 6 grounds on the front battery from the rear bank plus the chassis and engine grounds....Could I do some grounds off the rear bank to the alternator bracket? Im going to be running about 15,000 watts off the rear bank. Any help would be appreciated thanks!
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
For 5k watt...one run of 0ga +-should support it. Because one 0ga at 14.4 volts at 5k watts, your amp draw is 347amps....and one 0ga should support 150amp draw from a amp,found that at the12volt.com site. Hope that helps
How many alts are you running ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I'm running 3 dc 300 amp alts
Skyhigh wire
some batteries
  • Who's Online   0 Members, 0 Anonymous, 1346 Guests (See full list)
