srool Posted February 21, 2013 Report Share Posted February 21, 2013 I'm going to flare 4" PVC tube, I calculated with BB6P a 37 cm port length. My question is: what should be the tube length before the flare? I assume I need to keep a straight 37cm beside the flares, don't I? Link to comment Share on other sites More sharing options...
Joe X Posted February 21, 2013 Report Share Posted February 21, 2013 Like this: Or go here: http://www.psp-inc.com/tools.html Enter the data requested to get both the non flared as well as the flared port length, it should be close enough even if using non PSP ports. Link to comment Share on other sites More sharing options...
littlehitter Posted February 21, 2013 Report Share Posted February 21, 2013 I would buy a bit of extra and a slip coupling. Then you just flare the ends and cut the extra out of the middle and put it together with the coupling. Current System: Clarion CZ702 Stock 5 channel amplifier Infinity Reference 4022i 4" GRS 6.5" Audiopipe 1800.1 2 RE Audio SEX V2's In a 4th order ported though the armrest 2003 130 Amp Toyota Highlander alternator Link to comment Share on other sites More sharing options...
srool Posted February 21, 2013 Author Report Share Posted February 21, 2013 Thanks ! I'll upload pics later of what I did. Link to comment Share on other sites More sharing options...
srool Posted February 22, 2013 Author Report Share Posted February 22, 2013 Here is the port I made, second try: I drilled it and then screwed it, but still it started to crack when I screwed it more than a bit. Is there a safe way to drill it? Is there a simple way to flat the lip so it would fit exactly to the box plate without any gaps (that I filled with silicon)? Link to comment Share on other sites More sharing options...
