mrlovethatbass21 Posted February 24, 2013 Report Share Posted February 24, 2013 As the title says I need to know the net of this box and tuning. outside box dimensions are 40w. 48L. 18h with three 8 " aero ports, im looking for a tunng around 35 hz. this is for 4 sundown zv3 15s. , 3/4" birch single layer all the way around and double baffle with probaly six 1" steel rod bracing. Link to comment Share on other sites More sharing options...
Carbon Posted February 24, 2013 Report Share Posted February 24, 2013 I use mac as well, It would be nice to have torres on hand Link to comment Share on other sites More sharing options...
mrlovethatbass21 Posted February 24, 2013 Author Report Share Posted February 24, 2013 I use mac as well, It would be nice to have torres on hand yea i no Link to comment Share on other sites More sharing options...
Carbon Posted February 24, 2013 Report Share Posted February 24, 2013 You could run boot camp... Link to comment Share on other sites More sharing options...
Borris The Blade Posted February 24, 2013 Report Share Posted February 24, 2013 You'll net around 14.95, I guessed on bracing displacement of .3. 3 12 inch long ports will give you 35hz tuning but only 10.08 port area per foot. Im no expert but thats what I came up with. It's like rubbing your wiener up against a sheep. Link to comment Share on other sites More sharing options...
Joe X Posted February 24, 2013 Report Share Posted February 24, 2013 So here is a suggestion for a box 4 Zv3 15s subs up/port back on rated power: Enclosure Specifications:Fb = 34.5 HzVb = 12.5 ft^3External Height = 19.5 inExternal Width = 40 inExternal Depth = 43.375 inPort Height = 5 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 40 x 43 3/8Left & Right Sides = 41 7/8 x 17 1/4Front & Back = 40 x 17 1/4L Port Internal Assembly Parts:Front to Back = 20 1/4 x 38 1/2 Visual of box (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 5" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
mrlovethatbass21 Posted February 25, 2013 Author Report Share Posted February 25, 2013 So here is a suggestion for a box 4 Zv3 15s subs up/port back on rated power: Enclosure Specifications: Fb = 34.5 Hz Vb = 12.5 ft^3 External Height = 19.5 in External Width = 40 in External Depth = 43.375 in Port Height = 5 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 40 x 43 3/8 Left & Right Sides = 41 7/8 x 17 1/4 Front & Back = 40 x 17 1/4 L Port Internal Assembly Parts: Front to Back = 20 1/4 x 38 1/2 Visual of box (generic dimensions): Important notes: - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know. - All trunk boxes built outside the car need to fit in their way in not just have the right dimensions. - The port needs 5" of free airspace in front of it for proper operation. - Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
mrlovethatbass21 Posted February 25, 2013 Author Report Share Posted February 25, 2013 Here is the only thing I have 14k rms. I no they can take the power because I have four zv3 18s rite in my jeep and they handling that power with no sweat. Only problem is my box is to damn big for the truck so I'm downsizing Link to comment Share on other sites More sharing options...
