Low Voltage PROBLEMS
For some reason my voltage drops when my power and ground wires are connected to the amp. I used a multimeter to check my battery terminals under the hood and it read 12.6v-12.5v. I've tested the power and ground wires when they're not connected to the amp and it also reads 12.6v-12.5v. When I test the amp's pos and neg terminals when connected to the wires I get 7-4v. The amp will turn on, along with a bright green light that soon gets dim then goes off. I used different amps and I still get the same readings.
I went to Mobile One and the install tech said I had bad grounds through out my truck. After messing with the grounds under the hood, they all read 12v+ and I still have the same problem.
So whats the problem?
'01 2DR GMC JimmyPioneer DEH-6300UBMB Quart 6.5'sSoundown Audio SA 8 V2'sMTX RT-202 GONEAudiopipe AP-1800.1D GONE
Bass-less :angry2:
No one? No one knows?
Bass-less :angry2:
Double check all fuses and connections(this means go outside and do it. Don't assume). You might have a partially blown fuse that *looks* fine but really isn't.
Is the amp running with a load (speakers) or are you just turning it on?
Make sure nothing else is connected to the amp when you try this.
What is the voltage at the battery when you connect the amp power wires and attempt to turn it on and the amp shows ~7V?
What gauge are these power wires?
Double all connections between the battery and the amp for corrosion or bad connections.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Is this with the car on and running? Also if you have a second batt in the back check to make sure it's grounded properly cause I had a similar problem because mine wasn't grounded good and not getting charged so My amps would get really dim and almost cut off.
THE ANTHRACITE DYC CRUISER
-Fully dipped anthracite grey pt cruiser
-4 skar vvx 12's (version 1)
-Mechman 240 amp alt -Big three in Cadence 1/0
-1 deka intimidator g31 blacktop under the hood
-1 C&D 140ah Batt & 1 C&D 55ah batt in the rear
-Re audio/soundstream mids and highs
-Hifonics Zues 600.4
-DC Audio 3.5k
  • Who's Online   0 Members, 0 Anonymous, 1977 Guests (See full list)
