sbg Posted February 26, 2013 Report Posted February 26, 2013 so i am doing some clean up of wires and fixing of my platform that my sub box sits on, moving my amp.... guy at a shop told me i should move my box so that the ports fire at the driver side of the truck not the passager side, that it would be louder. is this true? so it got me thinking... should the box be all the way back to the gate as far as it will go? or all the way to the seats? and should i slide the box so that the ports have alot of room between them and the wall of the truck? or have the ports right up next to the side of the truck? i know people are going to say well test test test but i just wanted to see what others are doing. pic to help out with what i am talking about. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Joe X Posted February 26, 2013 Report Posted February 26, 2013 Try firing the ports towards the rear gate any side that they are mounted right now, two aeros for 6 subs.. must be big aeros I guess. Also 6 subs hardly can be wired to match the standard 1 ohm impedance..
sbg Posted February 26, 2013 Author Report Posted February 26, 2013 Try firing the ports towards the rear gate any side that they are mounted right now, two aeros for 6 subs.. must be big aeros I guess. Also 6 subs hardly can be wired to match the standard 1 ohm impedance..to long to fire ports at gate. Have to fire at side, I didn't build the box a guy I know who works for a shop in my town built the box. It's 2 boxs with a extra baffle to hold them together. Each box has a 6" I think. Said they are at 32hz . On my dmm ohm load is 1.4 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted February 26, 2013 Author Report Posted February 26, 2013 http://i1153.photobucket.com/albums/p514/sbg24231/B58148FC-050B-4198-A57A-64CD306E57A0-1673-000001DB7A6D5E8F_zps5c1f11b4.jpg 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
dfoland93 Posted February 26, 2013 Report Posted February 26, 2013 For the port, give it more room so move it further away from the wall (since im guessing from the picture their isnt too much room), my friend in his civic si made a little MDF part against the wall his port was facing so that it would roll off that instead of vibrating through the metal. So thats something you could try out as well The spot with least resistance LOL. I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring. how many poeple work there 3 or 4 lol At crescendo HQ? probably 2-3 At the sweatshop in china? 30,000 children No Engine
Joe X Posted February 26, 2013 Report Posted February 26, 2013 Those 6" port would need 6" of free airspace in front of them to work properly, I don't really think judging from the pic that you have the clearance. I would just mod the box.
sbg Posted February 26, 2013 Author Report Posted February 26, 2013 For the port, give it more room so move it further away from the wall (since im guessing from the picture their isnt too much room), my friend in his civic si made a little MDF part against the wall his port was facing so that it would roll off that instead of vibrating through the metal. So thats something you could try out as welllot more room then it looks like in pic. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
iKidwell Posted February 26, 2013 Report Posted February 26, 2013 idk where your port is on that box, cant tell from pics. From my experience, about 6" away from back hatch if you're firing at the back, always fire to drivers side. I'm personally going with subs up port firing towards the driver side wall (not back). people have had a lot of luck. But yes, fire drivers side for loudness in the explorer. c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old. i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer. 2003 Infiniti G35 Sport Sedan Build in Progress
sbg Posted February 26, 2013 Author Report Posted February 26, 2013 idk where your port is on that box, cant tell from pics. From my experience, about 6" away from back hatch if you're firing at the back, always fire to drivers side. I'm personally going with subs up port firing towards the driver side wall (not back). people have had a lot of luck. But yes, fire drivers side for loudness in the explorer. ports are on the drivers side in the pic, I just moved it to that side before the pic but didn't hook it back up yet, 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
kbsmoker Posted February 26, 2013 Report Posted February 26, 2013 On the meter it will be louder firing to the driver side...but not necessarily to the ear. Like others said keep about 6-8in away from the side. www.dcsoundlab.comyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3 SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator
