Antonio Moore Posted February 27, 2013 Report Posted February 27, 2013 Don't know how to use networks on 80prs
STEALTH808 Posted February 27, 2013 Report Posted February 27, 2013 did you change the switch on the side of the unit to Nw? then reset it? if you have done that then go to network 1. choose what frequencies and filters you want to adjust(there should be a low pass, mid high pass, mid low pass, high high pass.... once you are on the highlighted one, then press back. then go to network 2 and 3.. there you can change the settings. TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET 150Db Club 160Db club in the future I see krakin as a threat
Antonio Moore Posted February 27, 2013 Author Report Posted February 27, 2013 I had problems trying to locate that switch and how do I reset
Antonio Moore Posted February 27, 2013 Author Report Posted February 27, 2013 And do you know how to use the ad card slot??
bcbrassard Posted February 27, 2013 Report Posted February 27, 2013 Switch is underneath the head unit and it take a very small screw driver to get to. Look thru yout install instruction or Pioneer website for more instructions.
Antonio Moore Posted February 27, 2013 Author Report Posted February 27, 2013 Is it the switch that has L and H by it,
Jessica Posted February 27, 2013 Report Posted February 27, 2013 That switch is for the input sensitivity on the RCA in. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
AI James Posted February 27, 2013 Report Posted February 27, 2013 its clearly marked on the pioneer manual where to flick the switch and the correct procedure for doing so.
DrewJones Posted February 27, 2013 Report Posted February 27, 2013 If you're having this much issue even turning it on, maybe you shouldn't be messing with it. lol TEAM SOUTH Bassahaulic Productions The ONLY Bright Atlantic Blue DiamondBoxx L Drew Jones Bassahaulic Productions 4 SSA ZCON 15"s 2 Sundown SCV-6000's 6 AGM G31's 161.6 @ 40Hz Outlaw 159.8 @ 36Hz Legal ┌∩┐(◣_◢)┌∩┐
Jessica Posted February 27, 2013 Report Posted February 27, 2013 Slide the metal sleve back a few inches, it is under it. Slide the metal locking sleve back and you will find it. i will post a pic in a sec Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
