Good speakers for straight factory swap.
TylerParrish
Hey guys, I got a new car....2013 Forte Koup. The stock system is pretty good, but I have 4 Cadence 6.5's layin around that I'll be swapping out once it warms up. What're some low watt speaker suggestion that I can just swap in and not have to deal with running them all to an amp?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
What are you going to do? Use the Cadence or buy new? You say both in your post
2004 Dodge Ram
Head unit- Alpine iDA-x305s
Sound processor- Clarion eqs746
Mids/Highs amp- Alpine MRV-F345
Sub Amp- Alpine MRD-M1005
Dash Speakers- (3) Dayton Audio rs75
Front Door- Skar SPX65c
Rear fill- Skar SPX tweters and Dayton ND140 midbass
Sub- Fi Audio SSD 15 high QTS
SHCA power/ground cables and Stinger interconnect
XS power D6500 under the hood and D680 in the amp rack
Big 3+ with SHCA
http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
Using the Cadence temporarily since I have them, but I'm looking for something of a little better quality.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Are you changing the head unit or leaving stock?
2004 Dodge Ram
Big 3+ with SHCA
Stock, that's the only reason I'm not amping it for now....if I replaced the head unit, it'd make the car look reallllly stupid.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Let someone else chime in... I really cant give a honest recommendation with your criteria. Factory amp?, head unit power?, factory speaker impedance all will affect your choice.
2004 Dodge Ram
Big 3+ with SHCA
Why not run a line-output converter from your factory head unit, then run an amp to it. You'd still get to keep your factory head unit, and be able to amp your speakers.
*Rebuid in progress*
The factory amps usually have built in cross overs that you can't change. It would be better to just bypass it and use your own amp.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
In that case....any good loc suggestions? I have waht seems to be an older LC1 i believe it is, but it isn't exactly the besssst quality or anything.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
I run a LC7 and it is a good linedriver, clean & powerful. There are alot chooses out there though. DD has one, RF 360.3 JL that i know of.
  • Who's Online   1 Member, 0 Anonymous, 713 Guests (See full list)
