Question to all the welders out there.
So I was about to get my stripper pole welded in by a friend of a friend, who welds for a living. And he told me that I had to disconnect my batteries or they would get damaged. For me this isn't an easy task. Have a bunch of amps and wood I would have to move just to get to the positive buss bar. I could however easily get to my grounds. How much truth is there to the battery issue? I have to experience with welding so getting more opinions.
im curious why you dont trust the guy that does this for a living?
Yes you need to, the plant will be grounded to the frame.
You really don't want that kind of voltage being on the same circuit as your batteries.
You can take a chance and ground as close to the piece as possible but it can turn out ugly.
ABS controller fried and the sort.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Not that I don't trust hime but its Because there is just as much info out there saying it isn't necessary from other people that do it for a living.
Is the main ground being disconnected enough? Or do both power and ground need to be disconnected? How about the PCU? Been reading a lot about that one too. That you should disconnect it.
I've welded my car many time batts connected
Maybe if he was grounding on the opposite side of the car but if he's grounding close to the spot if the weld should be fine
I see his concern with the batteries thing, kinda
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
The "electrons" need a path to ground
Leave ur car off and make sure he used the ground close to the spot ur welding not on the engine block or -terminal lol
SCSB
Build logs:
I wouldnt say you HAVE to but it would be a good idea. Why take a chance? It takes quite a bit of electrical current to weld. I was a welder for 2 1/2 years before I became an engineer. Ive had to replace cell phones from being in my pocket while welding on steal because the current had frizzed them out
Edit: if you decide to leave your batts hooked up you cantblame him for any damage that may ooccur
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
disconnecting the grounds should be fine. as long as you break the circuit you shouldn't have a problem. so it's ok that you cant really get to your + connections.
I'm not a welder but, electrically, that's what makes sense to me.
Thanks for all the replies everyone. I'll just end up unhooking my ground battery cables and the PCM just to be safe.
