Which comps
8 members have voted
  1. 1. chooose!!!
    • cadence CWM6-KIT
      1
    • PHOENIX GOLD RSD6CS
      2
    • MB QUART RCE-213 REFERENCE
      5
    • 0
Guest Nismofreak
well my mb are not the best speakers and need a update
it will be powered by a xxv gemmini
I will tun gains down to prevent damage to speakers or wire it up to 8-ohm
Guest MegaloManiac
whats your budget man? also what deck do you have again?
cause i want to get you to go setup custom, be a real DIYer. it will be cheaper too sort of.
Edited by MegaloManiac
Guest Nismofreak
about $140 a pop
and need 3 sets of comps or 1 set of coax and 2 sets of comps
got the alpine 9886 soon getting the imprint
Edited by Nismofreak
Guest MegaloManiac
well i am encouraging to go diy if you can go active, im assuming with imprint you can?(correct?)
check out some mids that went reviewed, closer to bottom are cheaper range.
http://www.zaphaudio.com/6.5test/
tweeters i will look up some more in morning.
id run a good pair of rainbow slc 6.5 with cal25 tweets for the front about 250 for the set. and a decent set of coaxials in the rear rather then then compromise with multipbe mediocre sets
Guest Nismofreak
yah but my front door panel are made for 2 6 1/2 comps on each doors and 1 6.5 comp in the back on each door
just so you know, just because your running 6.5's now doesnt automatically mean another set is f=gonna bolt right up with the the exact diameter of the ones you had your pods built for originally.
Edited by roscoe1129
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
