Joe X Posted March 12, 2013 Report Posted March 12, 2013 The box looks a bit crazy but just power them and see what they can do, I would have gone with 12s though but the have a lot of excursion. Sure if you didn't properly do the deflector inside the port will probably have some less port efficiency.
CleanSierra Posted March 12, 2013 Report Posted March 12, 2013 Dude, it would be so much nicer if you would copy the IMG tag and paste that in the text box, rather than the link. Having the pics right here is so much nicer than going to an external link of your photobucket I'm on my cell, didn't know u could do that..Yup, Im on my cell too and all you have to do is find the IMG tag, copy, paste in a text box. Voila! Im not the one you want to try to troll. Just a fyi for you.
sbg Posted March 12, 2013 Author Report Posted March 12, 2013 Dude, it would be so much nicer if you would copy the IMG tag and paste that in the text box, rather than the link. Having the pics right here is so much nicer than going to an external link of your photobucket I'm on my cell, didn't know u could do that..Yup, Im on my cell too and all you have to do is find the IMG tag, copy, paste in a text box. Voila! well thank u! for the info 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted March 12, 2013 Author Report Posted March 12, 2013 well in other news i just got done doing some testing and all is good i am only runing @ 2ohm so 600 rms off my amp, this setup is as loud as my 6-12s i just took out that was runing @ 1ohm for 1000 rms. + now i am getting almost no voltage drop! 14s and high 13 volts at full tilt! when i was runing the 6-12s at 1ohm i was geting bad bad voltage drop 14+ to 11 -10s at full tilt. cant wait to put some real power on the subs this summer. i will try and get some vids soon. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted March 12, 2013 Author Report Posted March 12, 2013 im still going to put it in.. i still can fit my hand back into the box to put it in so as soon as i can get it made it will go in. The box looks a bit crazy but just power them and see what they can do, I would have gone with 12s though but the have a lot of excursion. Sure if you didn't properly do the deflector inside the port will probably have some less port efficiency. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted March 12, 2013 Author Report Posted March 12, 2013 + i got the set of 10s new for 150$ so that what i got lol. The box looks a bit crazy but just power them and see what they can do, I would have gone with 12s though but the have a lot of excursion. Sure if you didn't properly do the deflector inside the port will probably have some less port efficiency. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted March 12, 2013 Author Report Posted March 12, 2013 still going to be put in... I would have liked to see a triangle in the back of the port, be sure to do that next time 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted March 14, 2013 Author Report Posted March 14, 2013 Well I'm going to put the 45s in tomorrow and the deflector in the port, I hope it helps this box out because now that I have a day of play time with it I am not happy at all with it the subs move like a son of a itch and I have a lot of flex from windows, roof, doors, and so on... but its not loud at all! It just flex's the shit out of my truck. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
