Whats the difference between the BIG 3 and the BIG 4?
Hey whats going on guys? Just wanted to know what the difference was between the big 3 and the big 4. I know its most likely 4 cables instead of 3 but what is the difference? What are you doing with the big 4 that you dont do with the big 3?
-Thanks
2005 Dodge Magnum
Kenwood DNX573S Double Din
NVX Big 3 Kit
NVX 0 Gauge Cable & speaker cable
XS Power V3100 Battery
Iraggi Alternator 320A
3.5" NVX Speakers
6.5" Incriminator Audio Components (just mids)
6x9" NVX Speaker
MVPA4 Amplifier
(2) 12" NVX VCW Subwoofers
XPLD3K NVX Amplifier
YouTube Channel
@CarlosTj664
basically its just an extra ground. with the big 3, you do the engine block to ground so with the big 4 you would do that but run a ground from alt casing to battery.
it goes to the same place bc the alt is grounded to the engine block. i would rather ground to the alt casing. i think its a better ground
Oh ok, so its just another ground to the alts casing? Got it! I was thinking about doing a big 3 but came across big 4 and had my doubts. If I have enough cable I will do the big 4 because having extra grounds doesn't hurt :D
2005 Dodge Magnum
NVX Big 3 Kit
3.5" NVX Speakers
6x9" NVX Speaker
MVPA4 Amplifier
YouTube Channel
@CarlosTj664
They way I always do the big 3:
Alt pos. To bat.
Bat neg to new better ground.
For engine block to new ground I always went from alt engine block mount to new ground. So I guess I accomplished engine block to ground and alt casing to ground in a single wire :/
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
  • Who's Online   0 Members, 0 Anonymous, 1867 Guests (See full list)
