lacking lows.
KiKaZz74
Some people can hear lows better than others, plus one 18 on 1500 tuned to 34 might not be enough to play the lows like you want. Usually when people kill lows it's with cone area or a lot of power, and lower tuning. You might want to check you roof while you are playing lows to see if it is flexing a lot too, might have to deaden it. But then again, some people lose lows when the deaden the roof.
Plus, you could try to lower the SSF like others have said
Well I don't I don't have a way to tell besides touching it. I dont let it get past warm. I play it at 35/50 on hu
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Roof doesn't move. Around 35-20 I get windshield flex. Under that I get minor door flex and back wall/ bed rail flex.
But I might just have to deal with the lows. But the 138 at 57 hz??? Guys running 500 watts on a 12 were beating me...
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
I think its a combination of your box and gains.
I did a rough measurement of your box and plugged it into torres and I come up with approximately 4.57^3 net and 38hz tuning. Thats way high if your trying to kill lows IMO. I imagine your sub is moving a lot on low notes but just isnt putting out much. At that tuning your should probably turn UP your ssf cause you are wasting power on notes your box isnt really designed to reproduce, that and the leakage isnt helping at all.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Ok anything I can do to change tuning?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
I think you expected too much out of 1 18 on 1500 tuned at 34 to be honest. But at the same time the score you said you didn't just doesn't seem right at all... hell I did a 143@43hz with 1 18 Fi Q on a AQ1200 in an Explorer with a shit designed box.
If I was you I would get another box designed by either RAM or BHE. Just my 2cents.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
I'd like a new box. But not now idt. Damn ill just have to see if I can work it in. Thanks guys. And gotta find someone to let me use their table saw. Lol
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
ideally you'll want to first address the possible clipping by having your gains set properly.
If you want to keep the box its not going to be pretty, you can extend your external ports by 7" each - thats in addition to the existing external port. That will keep your net volume the same and bring tuning down around 33hz - then a ssf of 30hz is more appropriate.
Probably better off with a new box tuned low from the start.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
did you try moving the port :unknw:
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
You don't NEED to use a table saw. All you really need for basic basic building is a skilsaw and a jigsaw. That's all I have needed to use
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
  • Who's Online   0 Members, 0 Anonymous, 454 Guests (See full list)
