Miguels Posted March 29, 2015 Author Report Posted March 29, 2015 Pics yet? i need to jack it up to takes pics of it.. one issue i have is that they ended up a bit too long and was rubbing on the rear this time. took the moldings off and it fixed the rubbing. i now have no molding on the rear wheel wells but looks centered. i might have someone fabricate new moldings my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
BassMechanic308 Posted March 29, 2015 Report Posted March 29, 2015 Pics yet? i need to jack it up to takes pics of it.. one issue i have is that they ended up a bit too long and was rubbing on the rear this time. took the moldings off and it fixed the rubbing. i now have no molding on the rear wheel wells but looks centered. i might have someone fabricate new moldings have to love the either center or non centered rear end from the factory. i bet the trailing arms were easier to install than the fuel pump was huh? try doing a 5x5 swap on an 78 b body. better yet, swap the entire frame from a 91 caprice to the 78 impala.......haha fun times. 1997 Ford Expedition, Alpine CDE-133BT, Alpine KTP-445 inline 4 channel, Infinity Reference 6x8(all 4 doors), Kicker ZX500.1 @ 2ohms on Vibe BlackDeath QB69's in 2^ft ported enclose. "Coming Soon"(all ordered awaiting dropoff to me) 2x Sundown Audio SA-8v2 D2, Lanzar Opti2000D monoblock, KnuKonceptz 0/1G wire kit plus extras, PAC LD10 and LC1, Custom Built Enclosure by ME!!!
Miguels Posted March 29, 2015 Author Report Posted March 29, 2015 so i have an update out with the old as you can see, i was having belt slip even with a 3/4 inch shorter belt. the next belt below that was 1 1/2 shorter so i got it even after thinking its a bit too small in with the new per mechman instructions i did not need ground but im a believer of overkill the ground was added to the rear bolt after the bracket was sanded down that beefy 2/0 sky high the belt was a bit hard but figured it out to get it in with no struggle all done my resting voltage before start up.. dont want to void warranty so the battery was topped off first start up.. this alternator has not whine at all. most HO alts i have used has had lots of whine, even my other mechman. dont know if its due to the technology or that this time i used the right belt size. got to love that cold voltage. hopefully it doesn't drop too much when hot. if it does i have the vcm to take care of that issue please note that i did not remove the singer due to its performance or issues. its something i did due to the hairpin and the tech mechman had to offer for my needs. Singer was not able to build me a hairpin on my case so i had no choice.. i have other plans for that singer and will go in my other build that i need bad for the power i will run my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Neto562 Posted March 29, 2015 Report Posted March 29, 2015 Damn that mechman looks really nice and beefy in the SS!!!! Good work bro!!
Miguels Posted March 29, 2015 Author Report Posted March 29, 2015 im liking this beast.. the reason i rev the engine was because my last mechman would jump on voltage to at least 15.9v. this one dont flinch at all and its damn quiet. my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
WaTTsLOk187 Posted March 30, 2015 Report Posted March 30, 2015 Pics yet? i need to jack it up to takes pics of it.. one issue i have is that they ended up a bit too long and was rubbing on the rear this time. took the moldings off and it fixed the rubbing. i now have no molding on the rear wheel wells but looks centered. i might have someone fabricate new moldings Ok something is wrong here. Aren't the 3cfab arms only 5/8's extended? I have 3/4 inch extended BMR's and have no issues front to rear on the rear wheel wells. 96 Impala SS Memphis 2000D, Memphis ST-3004, MB Quart RAA-2400, Custom PSI Tc9 12 's Ascendant Audio Poly Mids and Vifa XT25 tweets Active 97 RCSB Silverado 3way Crystal Comps, ID10 ported, Off a US acoustics 4085
Miguels Posted March 30, 2015 Author Report Posted March 30, 2015 5/8 extended. im thinking of going with 35 series tires my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
WaTTsLOk187 Posted March 30, 2015 Report Posted March 30, 2015 5/8 extended. im thinking of going with 35 series tires What wheel and tire setup is on there now. 96 Impala SS Memphis 2000D, Memphis ST-3004, MB Quart RAA-2400, Custom PSI Tc9 12 's Ascendant Audio Poly Mids and Vifa XT25 tweets Active 97 RCSB Silverado 3way Crystal Comps, ID10 ported, Off a US acoustics 4085
Miguels Posted March 30, 2015 Author Report Posted March 30, 2015 265/35r22 i meant go with 30 series tires my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
OrionStang Posted March 30, 2015 Report Posted March 30, 2015 Im confused as to what was touching due to the arms. Its a minor install. SMD Super Seller My Feedback Thread
