Ok guys i just read to properly gain match 2 diff amps i need to set with dd1 first then gain match them with cc1? Is this correct...
If this is the case i might as well purchase the t2500 instead of buying another rf1000.1bdcp and buying a cc1 and the dd1.... And this is not a bitching thread. More or less trying to keep costs to a minimum.
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
Yes. First set gain with the dd-1, then gain match, then set crossovers
a dd-1 and cc-1 could turn you a profit in the long run. not having them will not. i think that should answer your question. ;)
you sir are a smart man.......but at this moment in time i cant afford a cc1 and another 1000.1bd.....
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
i can sell my 1000.1 now and get the 2500 and a dd1.....
Sounds like a good plan to me!
Yeah i think one of the guys that live close to me has a dd1 so i could buy the cc1 and the 1000.1.....reason im tryin to stay with the 2 1000.1's is cause i have 4 d4 sa8's and wanna run them at 1ohm and if i get the 2500 i will be at 2 ohm which that amp still puts out over 3k
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
you could strap them and then you wouldn't have to gain match ? IIRC though strapped amps usually do double at 2ohms what one of them is rated at 1ohm... but doubles your stable rating also (one amp stable at 1ohm strapped amps stable at 2ohm) and whatever you wire it to it cuts the load in half (wired to 4ohm get ~2ohm) so unless you have a strong electrical that may not be good cuz you'll be running what... 4k at 1ohm on a 2ohm stable setup?
Thanks I was pretty excited about the alt myself. kind of like a school girl, in a dress, on a swing. lol
It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out.
My Build Log
