CXHBumpin39 Posted March 12, 2013 Report Posted March 12, 2013 Hey guys, so I bent the valves in my D15Z1 motor, I somehow lost the valve springs after I took it apart, I was wondering if the exhaust and intake valve springs are different? I noticed that they looked like they were different thicknesses and never noticed that before, anyways would the valve springs off a D16Z6 work on this motor as well or would it be too much for the stock valves to handle? Any help is appreciated
CXHBumpin39 Posted March 13, 2013 Author Report Posted March 13, 2013 Also does anyone know where to get valve springs for a D15Z1 reasonably if I can't use the ones from a D16Z6
Jessica Posted March 13, 2013 Report Posted March 13, 2013 you might try this place to get an answer, little more focused to what you want. http://www.k20a.org/forum/ Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
CXHBumpin39 Posted March 13, 2013 Author Report Posted March 13, 2013 Well if a Honda guy could help that would be great
Skullz Posted March 13, 2013 Report Posted March 13, 2013 Copied from D-series.org http://www.d-series.org/forums/engine-building/40658-all-engine-specifications-measuements.html VALVES & VALVE SPRINGS (D15Z1 ENGINE)--------------------------------------------------------------------------Intake ValvesFace Angle............................................. ..................... 45 degreesHead Diameter............................. 1.08" - 1.09" (27.4 mm - 27.6 mm)MarginStandard................................... .033" - .045" (.85 mm - 1.15 mm)Service Limit............................................. .......... .026" (.65 mm)Stem DiameterStandard............................. .2157" - .2161" (5.48 mm - 5.49 mm)Service Limit............................................. ....... .215" (5.46 mm)Valve Stem Installed Height - Measure from base of valve guide to tip of valve stemStandard......................... 2.093" - 2.112" (53.17 mm - 53.64 mm)Service Limit............................................. ... 2.122" (53.89 mm)Exhaust ValvesFace Angle............................................. .................... 45 degreesHead Diameter............................... .92" - .93" (23.4 mm - 23.6 mm)MarginStandard................................ .041" - .053" (1.05 mm - 1.35 mm)Service Limit............................................. ........ .037" (.95 mm)Stem DiameterStandard.............................. .2157" - .2161" (5.48 mm - 5.49 mm)Service Limit............................................. ........ .215" (5.45 mm)Valve Stem Installed Height - Measure from base of valve guide to tip of valve stemStandard........................... 2.093" - 2.112" (53.17 mm - 53.64 mm)Service Limit............................................. .... 2.122" (53.89 mm)Valve SpringsFree LengthIntakeStandard.......................................... .......... 2.157" (54.78 mm)Service Limit............................................. .. 2.127" (54.02 mm)ExhaustStandard.......................................... ......... 2.293" (58.23 mm)Service Limit............................................. . 2.257" (57.33 mm) 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
HatersGonnaHate Posted March 13, 2013 Report Posted March 13, 2013 Yes the valve springs have different compressed and relaxed specifications, so I'd advise against using it. It's a good way to drop a valve seat after a little bit. Go here for parts http://www.hondaautomotiveparts.com/ My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car.
CXHBumpin39 Posted March 14, 2013 Author Report Posted March 14, 2013 Well can someone look up the difference in valve springs and tell me if you think it would work, cuz idk where to find any of this stuff
Carbon Posted March 14, 2013 Report Posted March 14, 2013 Well can someone look up the difference in valve springs and tell me if you think it would work, cuz idk where to find any of this stuff Usually you can call a shop and they can give you some good info
CXHBumpin39 Posted March 14, 2013 Author Report Posted March 14, 2013 And they discontinued the valve springs
